The warm glow of too many gauges. |
emerygt350 |
Dec 9 2021, 03:26 PM
Advanced Member Group: Members Posts: 2,117 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
windforfun |
Dec 9 2021, 03:29 PM
Senior Member Group: Members Posts: 1,802 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
Don't they say that about plutonium?
Definitely not FAA approved, but very nice. (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) |
Shivers |
Dec 9 2021, 04:16 PM
Senior Member Group: Members Posts: 2,398 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
The shift knob doesn't light up? (IMG:style_emoticons/default/biggrin.gif) Maybe LED bulbs would give you a more consistent glow. Even when I first got first got mine, I do not remember the climate control being lit. Is that a later teener thing? (IMG:style_emoticons/default/confused24.gif)
Superhawk996 |
Dec 9 2021, 04:18 PM
914 Guru Group: Members Posts: 5,857 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
so hopefully that means you sucessfully got your wiring run though the tunnel area one way or another (IMG:style_emoticons/default/beerchug.gif)
emerygt350 |
Dec 9 2021, 04:23 PM
so hopefully that means you sucessfully got your wiring run though the tunnel area one way or another (IMG:style_emoticons/default/beerchug.gif) Yes, I got it through, thanks to all the great pics and advice. I found that the last person to mess with it (the oil pressure gauge install) had just drilled through the floor of the car right under the back access panel. I figured I would just go with that since it was already 'damaged' there. I sealed it all up with silicone caulk so no water or rust. |
FlacaProductions |
Dec 9 2021, 04:53 PM
Senior Member Group: Members Posts: 1,594 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
I just installed a Dakota Digital CHT gauge today and one of my PO's pushed a wire through the speedometer cable boot so I just followed suit and it pushed right through - easy.
I'd been dreading the install for a while but it turned out to be no big deal. Replaced the temp gauge in the center console after installing a combo/temp gauge up top. Still a new-ish car to me so still establishing baseline running characteristics. |
Van B |
Dec 9 2021, 05:05 PM
Senior Member Group: Members Posts: 1,602 Joined: 20-October 21 From: Maryland Member No.: 26,011 Region Association: None |
No sir, that is an appropriate amount!
Olympic 914 |
Dec 9 2021, 05:26 PM
Group: Members Posts: 1,672 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
Still need an AFR gauge
emerygt350 |
Dec 9 2021, 05:33 PM
Lo-Fi Version | Time is now: 26th May 2024 - 12:24 AM |
