QUOTE(Superhawk996 @ Dec 9 2021, 05:18 PM)
so hopefully that means you sucessfully got your wiring run though the tunnel area one way or another
Yes, I got it through, thanks to all the great pics and advice. I found that the last person to mess with it (the oil pressure gauge install) had just drilled through the floor of the car right under the back access panel. I figured I would just go with that since it was already 'damaged' there. I sealed it all up with silicone caulk so no water or rust.
