WTB new door stay |
WTB new door stay |
Medtner3 |
Dec 12 2021, 11:13 AM
Member Group: Members Posts: 180 Joined: 7-July 20 From: Cedar Park Member No.: 24,467 Region Association: None |
the pins on mine and one of the parts is worn so much that it pops. the rebuild kit does not help
I'm looking for a very newish part that does not have any wear on the pins To be honest I get a lot a spam of people selling junk parts, I really do need something as new as possible Thanks for any help |
bdstone914 |
Dec 12 2021, 10:10 PM
bdstone914 Group: Members Posts: 4,537 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
the pins on mine and one of the parts is worn so much that it pops. the rebuild kit does not help I'm looking for a very newish part that does not have any wear on the pins To be honest I get a lot a spam of people selling junk parts, I really do need something as new as possible Thanks for any help I dont have one but the passenger door side gets a lot less wear. |
Medtner3 |
Dec 13 2021, 09:36 AM
the pins on mine and one of the parts is worn so much that it pops. the rebuild kit does not help I'm looking for a very newish part that does not have any wear on the pins To be honest I get a lot a spam of people selling junk parts, I really do need something as new as possible Thanks for any help I dont have one but the passenger door side gets a lot less wear. Yep my problem is on the drivers side |
DLewis |
Dec 14 2021, 05:31 AM
Member Group: Members Posts: 63 Joined: 3-December 04 From: Poway, CA (was SF Bay area) Member No.: 3,212 Region Association: None |
I think I have one from the passenger side if that will work.
I will post a picture Dean |
Medtner3 |
Dec 14 2021, 09:31 PM
DLewis |
Dec 15 2021, 12:08 PM
914werke |
Dec 16 2021, 12:44 PM
"I got blisters on me fingers" Group: Members Posts: 10,142 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
the pins on mine and one of the parts is worn so much that it pops. the rebuild kit does not help I'm looking for a very newish part that does not have any wear on the pins To be honest I get a lot a spam of people selling junk parts, I really do need something as new as possible I dont have one but the passenger door side gets a lot less wear. Thanks for any help If it is the stop & not the union of the arm to dr post (most likely) the rebuild kits should fix it. I rebuild them & rarely have I seen the interior pins worn so significantly that they need replacing. Its almost always the pin in the arm/dr post that is the cause (along with 50 yr old grease & worn out arm /rollers) |
carl k |
Dec 16 2021, 03:57 PM
Member Group: Members Posts: 76 Joined: 19-August 08 From: San Jose, CA Member No.: 9,440 Region Association: None |
https://sierramadrecollection.com/door-stop...-76-p54184.html
@Medtner3 Maybe you should buy a new one? |
Medtner3 |
Dec 17 2021, 12:44 PM
https://sierramadrecollection.com/door-stop...-76-p54184.html @Medtner3 Maybe you should buy a new one? I did not even know these were available. Thanks. That is an expensive part for sure at $168 plus tax and shipping though |
Mikey914 |
Dec 18 2021, 02:10 AM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
How about buying the pin.
https://914rubber.com/door-stay-pin-for-porsche-914 I do even have some oversized ones so if you have a hole that’s oversized I may be able to help. PM me the size you need I may be able to get you a slightly larger one. Mark Attached thumbnail(s) |
Medtner3 |
Dec 18 2021, 10:32 PM
Thanks, Mark. I already bought the oversized pin from you and rollers which helped. but my remaining popping problem is the large / long pin with the "built in" washer and the small bracket the hole is wallowed out and the large pin is so worn
I already took care of the pin you have and worked great although I am still slightly loose on one door because I did a poor job of drilling the holes out (IMG:style_emoticons/default/sad.gif) I am thinking possibly the solution for me might be "pin sleeves" for both issues so I bought a couple and will likely try them I might have a lead for the long pin and small bracket. |
DLewis |
Dec 19 2021, 10:22 AM
Medtner3 |
Dec 21 2021, 12:57 PM
Thanks, Mark. I already bought the oversized pin from you and rollers which helped. but my remaining popping problem is the large / long pin with the "built in" washer and the small bracket the hole is wallowed out and the large pin is so worn I already took care of the pin you have and worked great although I am still slightly loose on one door because I did a poor job of drilling the holes out (IMG:style_emoticons/default/sad.gif) I am thinking possibly the solution for me might be "pin sleeves" for both issues so I bought a couple and will likely try them I might have a lead for the long pin and small bracket. It looks good PM sent |
904svo |
Dec 21 2021, 05:36 PM
904SVO Group: Members Posts: 1,118 Joined: 17-November 05 From: Woodstock,Georgia Member No.: 5,146 |
Medtner3 |
Dec 25 2021, 12:44 PM
Thanks DLewis took care of me with the Long Pin which was worn on mine the rest of my door stay is in good shape |
Lo-Fi Version | Time is now: 10th June 2024 - 11:06 PM |
