Guess what I did today.....and no. Im not working clean up for a hit on the, The Roloffs |
Mikey914 |
Dec 13 2021, 12:53 PM
The rubber man Group: Members Posts: 12,661 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Actually, took me 2 days to het this far.
Wasn't sure about the depth or composition of the concrete so decided to do something that will be overkill. Putting in pilings for a lift. Should be ready in January (IMG:style_emoticons/default/piratenanner.gif) Attached thumbnail(s) |
Dec 13 2021, 01:18 PM
914Mels |
Dec 13 2021, 03:35 PM
Member Group: Members Posts: 357 Joined: 20-June 11 From: Santee Member No.: 13,221 Region Association: Southern California |
What style?
mlindner |
Dec 13 2021, 05:35 PM
Senior Member Group: Members Posts: 1,520 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
pete-stevers |
Dec 13 2021, 05:43 PM
saved from fire! Group: Members Posts: 2,641 Joined: 10-October 04 From: Abbotsford,BC, Canada Member No.: 2,914 Region Association: Pacific Northwest |
Looks like fun Mikey. Wish I was closer to help. Put my lift in 10 years ago, best choice ever. Have fun and a great 2022. Best, Mark Just wondering how the scissor lift guys put engines in? I wouldn't mind one because I like how they recess into the floor...outta sight out of mind |
mlindner |
Dec 13 2021, 06:02 PM
mlindner |
Dec 13 2021, 06:07 PM
Just for all....I get the two post lifts and the four, very nice.
The scissor lift in the floor is a giant 4 x 8 work bench that comes out of the floor for your Porsche, snowmobile , lawnmower or any big project you have. |
pete-stevers |
Dec 13 2021, 06:38 PM
Hi Pete. The lift works so good for engine install and removal I can'd believe it. Had to build a low profile box for both the engine an trans. lower down and bolt up. Mark Sorry for the hijack Mikey!!! But Mlinder how did you get that sexy six engine from falling into the hole? |
Mikey914 |
Dec 14 2021, 07:55 AM
Went with the Twin Bursch for less than 3k delivered, German design. Seemed to be the best built lift for the buck. I just need to finish digging out the pilings. Will be more than sufficient for the 914 / 911 applications.
rhodyguy |
Dec 14 2021, 08:55 AM
Too tall for my garage. I'm not penetrating the lid for anything.
siverson |
Dec 14 2021, 01:44 PM
Advanced Member Group: Benefactors Posts: 2,448 Joined: 5-May 03 From: San Diego, CA Member No.: 654 Region Association: Southern California |
Hi Pete. The lift works so good for engine install and removal I can'd believe it. Had to build a low profile box for both the engine an trans. lower down and bolt up. Mark Sorry for the hijack Mikey!!! But Mlinder how did you get that sexy six engine from falling into the hole? I have the same setup. Works great with a 914. -Steve |
mlindner |
Dec 14 2021, 03:08 PM
Sorry Pete, missed the part about engine install....I have two 1 x 8s with a steel rib on the back cut to fit the curb. When I bring car down to install height I put the boards down and roll the engine/trans forward.a Also a bunch or 80lb bags of salt in the truck for ballast . I did do the scissor mod-job, cutting out the rear bar with a replacement after. Mark
mlindner |
Dec 14 2021, 03:22 PM
Keep showing us pictures Mikey914
mlindner |
Dec 14 2021, 03:43 PM
Mikey, I keep looking at those pictures...did you use a jackhammer instead of a cement saw...Mark
Dec 14 2021, 06:45 PM
Looks like a saw cut and then broken with the hammer.
Mikey914 |
Dec 15 2021, 11:20 AM
Looks like a saw cut and then broken with the hammer. Winner winner chicken dinner. Tried to start with a sledgehammer / pry-bar and after 90 min saw I was getting nowhere. The concrete was stronger than thought as well as the mesh not getting completely cut as it was laying on the graven in some spots. |
Lo-Fi Version | Time is now: 15th May 2024 - 08:43 AM |
