Suspension question |
mlindner |
Dec 19 2021, 08:23 AM
Senior Member Group: Members Posts: 1,520 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
bkrantz |
Dec 19 2021, 08:32 AM
914 Guru Group: Members Posts: 7,763 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
That hoop looks like the stock size.
mlindner |
Dec 19 2021, 08:42 AM
The inside diameter is 3/4" and the width with rubber collar is 3/4"
914Sixer |
Dec 19 2021, 08:59 AM
Looks like a stock bushing would work. At $4 each, cheap enough to try.
rgalla9146 |
Dec 19 2021, 09:48 AM
Advanced Member Group: Members Posts: 4,552 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
The ID of the stock link is tapered toward the middle...not just tubular.
Fingers crossed. Attached thumbnail(s) |
mlindner |
Dec 19 2021, 10:21 AM
I'm see on a few site that the ID hole is 8mm.....but the bushing with metal insert is 9.5mm ID. So, small bolt that attaches to the A-arm and a large bolt 9.5mm with bushing attaching to the sway bar arm.
mlindner |
Dec 19 2021, 10:36 AM
Mark Henry |
Dec 19 2021, 11:27 AM
It looks like it would take a front sway drop link bushing if you drill the inner ferrule out.
mlindner |
Dec 19 2021, 12:01 PM
I think your right Mark, will try that. Happy Holiday, Mark L.
Mark Henry |
Dec 19 2021, 12:22 PM
IIRC you can just push the ferrule out, then try to drill it out.
Mikey914 |
Dec 20 2021, 02:31 AM
The rubber man Group: Members Posts: 12,667 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
They should fit.
Lo-Fi Version | Time is now: 16th May 2024 - 10:19 AM |
