mlindner
Dec 19 2021, 08:23 AM
As you can see in the picture. My 40 year old Waltmister drop link bushings have worn out. Any chance the 914 bushing listed in 914 rubber fit. Or some other source. Thanks, Mark
bkrantz
Dec 19 2021, 08:32 AM
That hoop looks like the stock size.
mlindner
Dec 19 2021, 08:42 AM
The inside diameter is 3/4" and the width with rubber collar is 3/4"
914Sixer
Dec 19 2021, 08:59 AM
Looks like a stock bushing would work. At $4 each, cheap enough to try.
rgalla9146
Dec 19 2021, 09:48 AM
The ID of the stock link is tapered toward the middle...not just tubular.
Fingers crossed.
mlindner
Dec 19 2021, 10:21 AM
I'm see on a few site that the ID hole is 8mm.....but the bushing with metal insert is 9.5mm ID. So, small bolt that attaches to the A-arm and a large bolt 9.5mm with bushing attaching to the sway bar arm.
mlindner
Dec 19 2021, 10:36 AM
OK, maybe I should have taken more pictures. The end with the helm joint is a 5/16 bolt (all good), but the larger end that needs the rubber bushing and metal sleeve is a 3/8th bolt or about 9.45 ID.
Mark Henry
Dec 19 2021, 11:27 AM
It looks like it would take a front sway drop link bushing if you drill the inner ferrule out.
mlindner
Dec 19 2021, 12:01 PM
I think your right Mark, will try that. Happy Holiday, Mark L.
Mark Henry
Dec 19 2021, 12:22 PM
IIRC you can just push the ferrule out, then try to drill it out.
Mikey914
Dec 20 2021, 02:31 AM
They should fit.
