What size Webers are these? |
billh1963 |
Dec 20 2021, 05:09 PM
Car Hoarder! Group: Members Posts: 3,402 Joined: 28-March 11 From: South Carolina Member No.: 12,871 Region Association: South East States |
Before I put them up for sale I need to know what size they are. Pairs I've seen in the past had the size stamped at the base or on the body. This one has "40 44 IDA" at the top. Which is it? Is there another place to look?
BTW...anyone know who Florida VW was? Thank you |
billh1963 |
Dec 20 2021, 05:11 PM
I think I answered my own question...last picture.... the carb on the left looks like it shows a 40 on the body above the pump?
914Mels |
Dec 20 2021, 05:47 PM
Member Group: Members Posts: 357 Joined: 20-June 11 From: Santee Member No.: 13,221 Region Association: Southern California |
The 40 0r 44 refers to the barrel size if you can measure that.
Root_Werks |
Dec 20 2021, 06:10 PM
Village Idiot Group: Members Posts: 8,319 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Air cleaner base says 40/44 meaning it'll fit either. Carbs look like 40's to me.
Measure them, easy enough. |
roblav1 |
Dec 20 2021, 06:11 PM
Senior Member Group: Members Posts: 528 Joined: 18-September 12 From: KY Member No.: 14,943 Region Association: MidAtlantic Region |
Those are ancient! Most sold back then were 44 IDFs. I'd have to check my book, but I don't think Weber made double 40 or 44 IDAs. Given the air cleaner base, I'd say 40 IDF.
infraredcalvin |
Dec 20 2021, 06:27 PM
Distracted Member Group: Members Posts: 1,515 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California |
Almost looks like the gaskets are 40s, but the barrels themselves look larger (shadow below the gasket).
zig-n-zag |
Dec 20 2021, 07:04 PM
Member Group: Members Posts: 182 Joined: 18-May 06 From: Hawaii Member No.: 6,024 |
An old Hot VW mag shows a Florida VW & Porsche from Hialeah, Fla.
Mark Henry |
Dec 20 2021, 07:43 PM
They're IDF.
There is two barrel IDA's but they are the almost exact same as a 911 IDA just one barrel short. They also only came in 48mm (original weber) size although guys would bore them to 52mm and there were some aftermarket 2 barrel IDA carbs made. Racers choice for NA type one drag racing. |
rfinegan |
Dec 21 2021, 07:10 AM
Senior Member Group: Members Posts: 973 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region |
Looking the short boost Venturi, I would say you have 40 IDF with early Italian fuel pump push rods too
billh1963 |
Dec 21 2021, 08:03 AM
Are parts still available for these? Sounds like more modern ones are a different configuration. I'd like to rebuild them. Not sure where you would go to source 'ancient' parts....
billh1963 |
Dec 21 2021, 08:04 AM
Mark Henry |
Dec 21 2021, 09:29 AM
Partsklassic has a lot of parts for IDF, a bit spendy, but fast service and all the little parts are well labeled in conjoined baggies.
https://www.partsklassik.com/csearch.aspx?C...rch=weber%20idf There's also a chap on ebay from Italy that has a good selection. |
billh1963 |
Dec 21 2021, 09:52 AM
Partsklassic has a lot of parts for IDF, a bit spendy, but fast service and all the little parts are well labeled in conjoined baggies. https://www.partsklassik.com/csearch.aspx?C...rch=weber%20idf There's also a chap on ebay from Italy that has a good selection. Thank you! |
Mark Henry |
Dec 21 2021, 09:59 AM
Partsklassic has a lot of parts for IDF, a bit spendy, but fast service and all the little parts are well labeled in conjoined baggies. https://www.partsklassik.com/csearch.aspx?C...rch=weber%20idf There's also a chap on ebay from Italy that has a good selection. Thank you! IIRC aircooled.net also stocks quite a few IDF parts. |
FJ1200 |
Dec 21 2021, 11:40 AM
Member Group: Members Posts: 61 Joined: 26-December 18 From: Harpswell, ME Member No.: 22,751 Region Association: North East States |
I bought master rebuild kits for my Italian 40 IDF's from Pierce Manifolds. The parts were original OEM and the kit was VERY complete.
Dan |
KSCarrera |
Dec 22 2021, 09:55 AM
Member Group: Members Posts: 308 Joined: 31-January 19 From: UK Member No.: 22,846 Region Association: England |
Back in the 1980s when Weber IDFs first hit the VW scene, various companies (notably Claudes Buggies – today known as CB Performance) marketed these as '40IDAs' in kits for the air-cooled VW motor. The reason for this was that 48IDAs were well known in the VW performance world for use on hot street and drag race Bugs, but nobody had heard of IDFs. Selling them as 'mini IDAs' was purely a marketing gimmick.
Parts are easy to come by - at least over here in Europe. |
Lo-Fi Version | Time is now: 16th May 2024 - 03:52 AM |
