Sold Side Shift Conversion Package - no trans parts |
bdstone914 |
Dec 22 2021, 06:27 PM
bdstone914 Group: Members Posts: 4,537 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I have assembled the parts needed to convert to a side shift trans. This does not include the transmission parts needed to convert the trans.
The engine bar, shift rods and motor mount brackets are powder coated. New engine mounts, bushings and hardware needed are included. Some of tge bushings are not in the picture but are included. The shifter coupler that installs on the end of the rear shift rod at the tra nbn s is a modified early coupler. I welded on an extension of metric tube. Price for trans conversion parts $500. Shipping will range from $30-$50 depending on location. Attached thumbnail(s) |
MaukaDoug |
Dec 26 2021, 10:56 AM
I'm new here ... Group: Members Posts: 0 Joined: 24-December 21 From: Edwards, CO 81632 Member No.: 26,194 Region Association: Rocky Mountains |
I have assembled the parts needed to convert to a side shift trans. This does not include the transmission parts needed to convert the trans. The engine bar, shift rods and motor mount brackets are powder coated. New engine mounts, bushings and hardware needed are included. Some of tge bushings are not in the picture but are included. The shifter coupler that installs on the end of the rear shift rod at the tra nbn s is a modified early coupler. I welded on an extension of metric tube. Price for trans conversion parts $500. Shipping will range from $30-$50 depending on location. Hello bdstone914, I’m interested in purchasing your side shift conversion package. Shipping will be to Edwards, CO 81632. I just sent you an e-mail as well, with additional contact info. Thanks, -Doug |
Lo-Fi Version | Time is now: 11th June 2024 - 06:04 AM |
