Halon fire extinguisher, Where to buy? What size? |
Hawk |
Jul 23 2003, 02:28 PM
Member Group: Members Posts: 351 Joined: 31-December 02 From: Ann Arbor, Michigan Member No.: 57 |
After a search I can find no recommendations here on where to buy a halon extinguisher to carry in a 914. Or what size would be adequate. Anybody?
Not interested in halotron extinguishers. Give me the real thing. Thanks, -hawk (IMG:style_emoticons/default/fighting19.gif) |
tat2dphreak |
Jul 23 2003, 02:38 PM
check harbor freight... I thought I saw some there the last time I was in there
gklinger |
Jul 23 2003, 02:52 PM
doh! Group: Members Posts: 316 Joined: 14-January 03 From: Tempe, AZ Member No.: 146 Region Association: Southwest Region |
take a look at: http://www.h3r.com/products/a1600_2_hv.htm This is a 3.5 lb unit, they've got others from 1.25 lb up to 9 lb.
Brad Roberts |
Jul 23 2003, 02:54 PM
Yep.. buy the small one and attach a large magnet to the cross beam for the seat rails. A magnet will hold the fire ext. in place and you dont have to drill holes into your six. (it tucks nicely under the seat cushion and your legs)
B |
GWN7 |
Jul 23 2003, 06:20 PM
I had a couple up on the classififieds last month....
"This is a 6 pound automatic Halon 1211 extinguisher. Designed to automatically extinguish fires in enclosed spaces up to 256 cubic feet. Unit is new. Comes with mounting bracket, discharge lamp plate, discharge indicator with buzzer, manual discharge activation pull station with 10' of cable, wiring diagrams and owners manual. Total unit weight is 6.28 lbs. Underwriters Laboratories listed. Replacement cost $466.00 for a similar unit without the manual activation. $400.00 or best offer" and "This is a 3 pound automatic Halon 1211 extinguisher. Designed to automatically extinguish fires in enclosed spaces up to 128 cubic feet. Unit is new and comes with mounting bracket and owners manual. Total unit weight is 6.28 lbs. Underwriters Laboratories listed. Replacement cost (DriveWerks) $159.95 for a similar unit. $100.00 or best offer" Can deliver it to Ohio next month if your interested. Attached image(s) |
GWN7 |
Jul 23 2003, 06:21 PM
and 6 lbs
If not, I'm putting them up on evilbay end of the week. Attached image(s) |
kdfoust |
Jul 23 2003, 06:23 PM
Senior Member Group: Members Posts: 694 Joined: 2-January 03 From: Riverside Member No.: 71 Region Association: Southern California |
QUOTE(Brad Roberts @ Jul 23 2003, 12:54 PM) Yep.. buy the small one and attach a large magnet to the cross beam for the seat rails. A magnet will hold the fire ext. in place and you dont have to drill holes into your six. (it tucks nicely under the seat cushion and your legs) B Dude, are you serious? Like what if you want to find it after a crash? |
redshift |
Jul 23 2003, 06:28 PM
I think if you crash a 914 hard enough to need fire equipment, someone else will be looking for the extinguisher.
(IMG:style_emoticons/default/happy11.gif) M |
mskala |
Jul 23 2003, 07:34 PM
I'm using a Halon one on my -6. Paranoid about carb fires
even after all known mods. You can run a 5-lb bottle in the place of the center cushion without any drilling of holes. First pic, bracket mounted in an existing hole in the crossmember, and the 2 sheet metal screws in the back which used to hold down the tray. Attached image(s) |
mskala |
Jul 23 2003, 07:36 PM
Bottle in place. Doesn't really get in the way at all.
Put something under it if the tar is removed, or your seatbelts will clank when you throw them in there. Attached thumbnail(s) |
Hawk |
Jul 24 2003, 06:05 AM
Been shopping all the race sites on line. Just found Perf Prod with time limited 20% discount offer would bring 5 lb halon extinguisher to less than $150, if any one else is interested.
-hawk |
Lo-Fi Version | Time is now: 14th May 2024 - 01:54 AM |
