Windshield install, Mispunched trim keeper hole |
Morph914 |
Dec 30 2021, 11:50 AM
Member Group: Members Posts: 435 Joined: 22-August 16 From: St Augustine, FL Member No.: 20,326 Region Association: South East States |
I am in the process of preparing for my windshield install and when installing the trim keepers I noticed that the lower driver side hole was mispunched, instead of a clean hole like all the others this one pushed in some of the metal. I don’t believe the trim piece will lock into the opening. I think I will have to drill a new hole unfortunately. Shall I drill above or below the original hole?
The install of the trim keepers is going well, I am using a small socket to set the clip and then using a punch to push in the pin. |
Mikey914 |
Dec 30 2021, 11:58 AM
The rubber man Group: Members Posts: 12,667 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I would go beside not abouve or below. The height is important as it can push up or not engage if not correct.
I do have a small section of window trim I can send you if you PM me. You may find that the hole is ok and will engage if you want to check it. Mark |
Morph914 |
Dec 30 2021, 01:06 PM
I would go beside not abouve or below. The height is important as it can push up or not engage if not correct. I do have a small section of window trim I can send you if you PM me. You may find that the hole is ok and will engage if you want to check it. Mark Ideally it would work best to drill a new hole beside the existing but there is not enough room, so I think I will go just below. I did try to get the keeper into the original hole with no luck, I do have extra so not a big deal. All the others went in with no problems. Cheers, John |
Montreal914 |
Dec 30 2021, 02:14 PM
Senior Member Group: Members Posts: 1,559 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
Thank you for sharing the process.
Good luck and keep the pictures coming. I am looking forward to getting to this point. (IMG:style_emoticons/default/smile.gif) |
Morph914 |
Dec 30 2021, 02:28 PM
What is being used for primer on the windshield gutter, or is this even necessary with the butyl tape?
In Auto Atlanta’s video it looks like they are using the 3m 08681 primer. Just didn’t want to spend $30 to 40 if I don’t have to. |
PanelBilly |
Dec 30 2021, 03:28 PM
914 Guru Group: Members Posts: 5,807 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
When I visited Black Forest Racing a few weeks ago I ask about installing trim. The tip John shared was to put a dab of silicone windshield glue on each clip when attaching the trim. Since the clips are likely broken anyways next time it’s removed the glue just adds a bit of adhesion. If the trim doesn’t snap into the clip 100%, the glue holds it on. Less chance of the trim flying off when your driving.
Lo-Fi Version | Time is now: 16th May 2024 - 01:30 PM |
