Are these 914-6 rear hubs? |
billh1963 |
Dec 30 2021, 01:42 PM
Car Hoarder! Group: Members Posts: 3,402 Joined: 28-March 11 From: South Carolina Member No.: 12,871 Region Association: South East States |
Going through my parts stash and came across these. Are these real 914-6 hubs?
Luke M |
Dec 30 2021, 02:11 PM
Senior Member Group: Members Posts: 1,371 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
Hubs are 69-73, 911/914-6 same part.
Spindles if they are 914 size cv's with coarse splines to fit 911 hubs then yes 6 parts. Axles would be 28 splines to be 914-6. Trans stubs same as 914 & 914-6 if 914 cv fits. |
billh1963 |
Dec 30 2021, 04:26 PM
Hubs are 69-73, 911/914-6 same part. Spindles if they are 914 size cv's with coarse splines to fit 911 hubs then yes 6 parts. Axles would be 28 splines to be 914-6. Trans stubs same as 914 & 914-6 if 914 cv fits. Splines count out as 28...looking like 914-6 is a possibility |
billh1963 |
Dec 31 2021, 12:56 PM
roblav1 |
Dec 31 2021, 02:42 PM
Senior Member Group: Members Posts: 528 Joined: 18-September 12 From: KY Member No.: 14,943 Region Association: MidAtlantic Region |
Transaxle flanges look like 10mm 4 bolt / 2 pin type, which would definitely make them 1969-1973 911, which is what you want for the -6. Same for CVs, stubs and hubs.
Check the axle length. 914-6 is slightly longer than 911. If all that stuff is 911, then it's perfect for a -6 conversion, and get the right length axles from Sway-a-Way. |
Eric_Shea |
Dec 31 2021, 04:58 PM
(IMG:style_emoticons/default/agree.gif) CV’s are too big for 914-6 stuff but “that’s the good news”. I never did understand 914-6 CV’s, axles etc.
All you’re missing are the aforementioned axles and you have what we put in every -6 build we do. (IMG:style_emoticons/default/smilie_pokal.gif) |
billh1963 |
Dec 31 2021, 05:13 PM
Thank you for the feedback!
Lo-Fi Version | Time is now: 16th May 2024 - 05:53 AM |
