What do these cylinder head numbers mean? |
DaveB |
Jan 3 2022, 12:46 PM
Member Group: Members Posts: 163 Joined: 25-November 21 From: Portland, Oregon Member No.: 26,107 Region Association: Pacific Northwest |
Below the valve cover there is a set of 3 numbers on the cylinder head. What do these indicate?
BTW - the water droplets in the background are a new feature. I thought the 996 was the first water cooled rear engine for Porsche, but this little engine has them beat. It seems the PO left the carbs off the engine. I got it onto the stand today, removed the exhaust manifold and found one side had water. Rotated the engine and had water dump out of an exhaust port. So glad I saved money on this instead of paying a few thousand more for a car that runs and was well taken care of. DaveB |
914Sixer |
Jan 3 2022, 01:38 PM
914 Guru Group: Members Posts: 8,885 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Casting numbers, may be a date code but do not know.
DaveB |
Jan 3 2022, 02:07 PM
DaveB |
Jan 3 2022, 02:10 PM
930cabman |
Jan 3 2022, 02:24 PM
Advanced Member Group: Members Posts: 3,066 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
Happy New Year (not)
That's ugly, good luck with the repairs |
914Mels |
Jan 3 2022, 05:46 PM
Member Group: Members Posts: 357 Joined: 20-June 11 From: Santee Member No.: 13,221 Region Association: Southern California |
With any luck that loose valve may not of gone thru the piston, keeping the lower end intact.
914sgofast2 |
Jan 3 2022, 05:52 PM
Senior Member Group: Members Posts: 617 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None |
The water has probably destroyed the pistons and cylinders, looking at the rust on the valve train.
DaveB |
Jan 4 2022, 10:42 AM
The water has probably destroyed the pistons and cylinders, looking at the rust on the valve train. The other head has a cracked valve which also let water leak into the piston chamber. Top end is basically toasted and it will cheaper to just replace than rework. The broken valve cracked the piston but the connecting rod looks straight. I've got the cylinders off and will dig into the rotating assembly this weekend. The PO showed me a video he took getting the engine started a few years ago. He put on a carb conversion and hot wired it. My guess is the car was sitting for 8 or 9 years with the intakes open gathering rust and snapped the seized parts when he decided to fire the engine. I knew something was wrong when I could smell gas mixed with the oil. DaveB |
ClayPerrine |
Jan 4 2022, 11:50 AM
Life's been good to me so far..... Group: Admin Posts: 15,470 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
(IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/icon8.gif) (IMG:style_emoticons/default/barf.gif)
That hurts to look at... Good luck. Clay |
914Mels |
Jan 4 2022, 12:00 PM
On old VW type 1 engines we used to check the rods for bends by pushing a wrist pin through them while they were attached to the crankshaft. If it slid through easily we knew the rods were straight. I think this works on the type 2 engine also. The rod bearings have to be installed to do this.
Porschef |
Jan 4 2022, 12:06 PM
How you doin' Group: Members Posts: 2,165 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
So glad I saved money on this instead of paying a few thousand more for a car that runs and was well taken care of. DaveB Violation of Rule #1 (IMG:style_emoticons/default/dry.gif) (IMG:style_emoticons/default/sad.gif) Maybe consider the money saved as tuition? (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 19th May 2024 - 05:12 PM |
