Want to buy Original 1.7 air cleaner, Looking for correct complete air cleaner for 1.7 motor |
jkb081 |
Jan 9 2022, 07:23 PM
Member Group: Members Posts: 78 Joined: 24-October 21 From: San Francisco, CA. Member No.: 26,018 Region Association: Northern California |
Looking for complete air cleaner with mounting bolt/wing nut for 73 1.7
Mikey914 |
Jan 9 2022, 07:35 PM
The rubber man Group: Members Posts: 12,652 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
It should be plastic lnot the metal one.
jkb081 |
Jan 9 2022, 08:56 PM
It should be plastic lnot the metal one. OK, thanks. I thought the 1.7 was metal, the 1.8 was plastic, and the 2-L was the big square metal one. Im not sure if I have an early or late 73. The numbers that are supposed to be in the front trunk, and in the rear trunk are missing. Both trunks have been sprayed with "bed liner" I cannot find/see the engine number either. I have looked at the area where it is supposed to be, but cannot see anything. |
JamesM |
Jan 10 2022, 08:22 AM
Senior Member Group: Members Posts: 1,895 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
It should be plastic lnot the metal one. OK, thanks. I thought the 1.7 was metal, the 1.8 was plastic, and the 2-L was the big square metal one. Im not sure if I have an early or late 73. The numbers that are supposed to be in the front trunk, and in the rear trunk are missing. Both trunks have been sprayed with "bed liner" I cannot find/see the engine number either. I have looked at the area where it is supposed to be, but cannot see anything. The earlier 1.7s (70-72) use a metal oil bath filter. 1973 1.7s they changed to a round plastic filter. 1.8s use a square plastic filter housing. The issue with the 73 round plastic housing is finding the proper filter elements for it. You can use the earlier metal filter as they are interchangeable however it would not be "correct" for the year. |
Lo-Fi Version | Time is now: 4th May 2024 - 09:06 PM |
