Want to buy Original 1.7 air cleaner, Looking for correct complete air cleaner for 1.7 motor |
jkb081 |
Jan 9 2022, 07:23 PM
Member Group: Members Posts: 78 Joined: 24-October 21 From: San Francisco, CA. Member No.: 26,018 Region Association: Northern California |
Looking for complete air cleaner with mounting bolt/wing nut for 73 1.7
jrmdir |
Jan 10 2022, 02:19 PM
Member Group: Members Posts: 224 Joined: 13-May 21 From: Central Ohio Member No.: 25,544 Region Association: Upper MidWest |
QUOTE[I see. Thank you. My issue is the intake horn is pressing down on the flapper rod that connects both flappers, thus preventing it from proper function. So I assumed I have the incorrect air cleaner.]QUOTE
The horn should point to the side of the car. See below. You should be able to rotate the bottom of the cleaner (with the horn) when the clips are undone. The top half's orientation is fixed by the rubber connector to the throttle body. As to the covered up numbers in the trunks, they would (should) be the same as the top number on the Karmann plate: 2639599. This means your car was built on the 3rd day of the 26th week (of 1973.) Or Wednesday, June 27th. This, and the high VIN# (27001) would put it fairly late in the '73 model run, which I believe would have ended in August or September. The scratched out bottom number is the original paint code. Ron |
Lo-Fi Version | Time is now: 4th May 2024 - 02:37 PM |
