Want to buy Original 1.7 air cleaner, Looking for correct complete air cleaner for 1.7 motor |
jkb081 |
Jan 9 2022, 07:23 PM
Member Group: Members Posts: 78 Joined: 24-October 21 From: San Francisco, CA. Member No.: 26,018 Region Association: Northern California |
Looking for complete air cleaner with mounting bolt/wing nut for 73 1.7
jrmdir |
Jan 11 2022, 02:23 PM
Member Group: Members Posts: 224 Joined: 13-May 21 From: Central Ohio Member No.: 25,544 Region Association: Upper MidWest |
Happy to help. I knew almost nothing about these cars 6 months ago and learned everything from the helpful folks here!
There are a lot of threads on engine numbers, and a lot of people more into them than I am, but based on the numbers on my original '73, yours look to be correct. Or at least not out of whack. Hopefully others will chime in. One thing you should do, if not already, is to put your info into the VIN Database (top thread in this forum) Once your car is slotted in, you may be able to see some engine #'s of cars that were built at or nearly at the same time. Could be a good gut check. Cheers, Ron |
jkb081 |
Jan 11 2022, 02:42 PM
Happy to help. I knew almost nothing about these cars 6 months ago and learned everything from the helpful folks here! There are a lot of threads on engine numbers, and a lot of people more into them than I am, but based on the numbers on my original '73, yours look to be correct. Or at least not out of whack. Hopefully others will chime in. One thing you should do, if not already, is to put your info into the VIN Database (top thread in this forum) Once your car is slotted in, you may be able to see some engine #'s of cars that were built at or nearly at the same time. Could be a good gut check. Cheers, Ron Thanks! |
Lo-Fi Version | Time is now: 5th May 2024 - 12:44 AM |
