Corbeau Seats fitment, How did you do it? |
pek771 |
Jan 25 2022, 01:07 PM
Member Group: Members Posts: 273 Joined: 23-November 05 From: Conover, NC Member No.: 5,175 Region Association: None |
I'd like to put in two Corbeau seats (they seem to be the best fit). Any of you put in any Corbeaus (any seats, really)? How did you mount them such that they fit?
I am a 38 waist size...I don't think I need a wide seat. I do have the stock 70 interior, which is still an option to spiff up and put in. TIA Pat |
DRPHIL914 |
Jan 25 2022, 01:16 PM
Dr. Phil Group: Members Posts: 5,759 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
depends on the style of the Corbeau seat, i had a set and being 6'1'' but 31'' waist, the set i had was really tight for me side to side so if you are a 38" waist, unless its all up front, its going to be really tight fit for you i think, and the bottom cusion too thick i sat too high,
they fit my friend who is 5'8'' 27'' waist and about 140#, and they fit him perfect. so it depends on which model seat. as far as mounting them i had to get their conversion brackets to bold the 914 sliders onto as the seat base mount holes don't line up . Post some pictures if you have some. |
d914 |
Jan 25 2022, 01:23 PM
Advanced Member Group: Members Posts: 2,331 Joined: 12-July 03 From: Atlanta, ga Member No.: 904 Region Association: South East States |
https://corbeau.com/classic-ii/
These fit existing sliders if memory serves. Maybe minor drilling to help line up. Put these in my old car years ago. g |
Steve |
Jan 25 2022, 01:27 PM
914 Guru Group: Members Posts: 5,570 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Steve |
Jan 25 2022, 01:36 PM
At one time I had Corbeau seats in my 914. The adapter brackets made the seat sit higher and I had to cut the seat cushion foam in half, so my helmet wouldn't hit the roof. JW at Ottos (RIP) shortened the stock seat bracket so the Corbeau seat could mount to it directly. He then bolted the stock seat bracket directly to the floor. This dramatically improved the height clearance. I still have the mount, but only for the drivers side.
Eric_Shea |
Jan 25 2022, 04:20 PM
PMB Performance Group: Admin Posts: 19,274 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
We're a Corbeau authorized dealer. The brackets are flat (and 914 guy cheap). (IMG:style_emoticons/default/wink.gif) Call if you need anything.
pek771 |
Jan 25 2022, 07:32 PM
Thanks Eric!
Freezin 914 |
Jan 25 2022, 08:04 PM
Senior Member Group: Members Posts: 845 Joined: 27-July 14 From: Wisconsin Member No.: 17,687 Region Association: Upper MidWest |
Anybody here have any of these seats in their cars? Pictures?
Steve |
Jan 26 2022, 10:04 AM
Anybody here have any of these seats in their cars? Pictures? Here are a couple of pictures in my blog, but not full shots. http://www.914world.com/bbs2/index.php?aut...;showentry=1018 Also check the install on Pelican. https://www.pelicanparts.com/techarticles/9...at_install3.htm |
Steve |
Jan 26 2022, 10:10 AM
We're a Corbeau authorized dealer. The brackets are flat (and 914 guy cheap). (IMG:style_emoticons/default/wink.gif) Call if you need anything. Yep, Eric you are correct. The brackets are only 1/4" thick. They just sat higher than a stock seat. It was easy to take the foam out of the bottom cushion and put something thinner in its place for AutoX and put the original foam back in for daily driving. Nice seats for the price. They also now have lots of options besides the Forza, so maybe the other seats might sit lower? |
KSCarrera |
Jan 27 2022, 07:59 AM
Member Group: Members Posts: 307 Joined: 31-January 19 From: UK Member No.: 22,846 Region Association: England |
By using a flat bar across the stock runners, the seats sit too high IMHO. To mount the Cobra RSR seats in my car I made cross braces which are 'stepped down' about 20mm and then bolt to the stock runners, which I'd removed from the original seats.
pek771 |
Jan 27 2022, 01:23 PM
Thanks Keith!
Lo-Fi Version | Time is now: 28th April 2024 - 01:24 PM |
