> Aftermarket EFI and wiring questions
jmargush
post Feb 2 2022, 06:07 PM
I am in the process of installing CB Performances EFI system.
I have a few questions in regard finding wires from the front of the car to the engine bay.
Fuel pump - Do the two wires that connect to the pump up under the fuel tank, run back to the engine compartment? I need to find a place to tie in the wires form CB's harness instead of running new wires all the way to the front.
Tachometer - Is there a wire that goes to the tach that I can connect to their drop for the tach?
Ignition - There is a drop labeled ignition is there a wire already back in the engine bay or do I need to run this up to the ignition switch?
- Lo-Fi Version Time is now: 7th December 2025 - 02:08 PM
