QUOTE(jmargush @ Feb 2 2022, 05:07 PM)
Fuel pump - Do the two wires that connect to the pump up under the fuel tank, run back to the engine compartment? I need to find a place to tie in the wires form CB's harness instead of running new wires all the way to the front.
Yes the 12v wire to the pump runs back to the stock relay board in the engine compartment. This relay is normally activated by the stock ECU grounding the appropriate pin on that 4 pin connector at the driver side rear of the board. Not sure how the CB system is wired but on my Megasquirt builds I just connect the fuel pump control wire to this pin and use the stock relays and wiring for the pump.
Tachometer - Is there a wire that goes to the tach that I can connect to their drop for the tach?
Yes, tach signal wire comes off the ignition coil. If the signal from the CB system is low voltage you will either need a tach signal adaptor or a small modification to the tach itself for it to work.
Ignition - There is a drop labeled ignition is there a wire already back in the engine bay or do I need to run this up to the ignition switch?
Yes, (assuming its just looking for a 12v ignition on source) again off that 4 pin corrector on the relay board that powers the stock ECU.
Everything you should need is already in the engine bay.
