1.8L L-Jet to 2056, what can I use? |
Rob-O |
Feb 5 2022, 12:18 PM
Senior Member Group: Members Posts: 1,252 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region |
Have a few threads about my engine dying, but wanted to ask this in a separate thread. Currently a 1.8L but want to do a 2056. If I buy a 2056 long block, I assume I can use all of my L-Jet. But I have questions:
1. Exhaust from my 1.8L will all fit and can stay, correct? I'm almost certain exhaust port spacing is the same on all engines for our cars. 2. I would need new upper engine tins since the spark plug location is different. Or do I plug and redrilll the 1.8L tins? 3. Do the rest of the tins from the 1.8L work? 4. If I use 2.0L upper tins, did they have a stanchion to attach a fuel pressure regulator? 5. I thought 1.8L FI runners have four bolts where they meet the head and 2.0L have three. Do I just drill the 1.8L runners for the third bolt (is there even room for that)? 6. Are the lengths and positions of the L-Jet runners even compatible with the 2.0L? Anything else I'm missing? |
914Sixer |
Feb 5 2022, 12:44 PM
Just use what you have. Get a 2 liter crank and rods. Build the 2056 from there. 912E engine was a 2.0 with L Jet. L-jet may need a little tuning, not sure on that part. 1.8 heads are good to use.
914werke |
Feb 5 2022, 01:43 PM
"I got blisters on me fingers" Group: Members Posts: 10,067 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Have a few threads about my engine dying, but wanted to ask this in a separate thread. Currently a 1.8L but want to do a 2056. If I buy a 2056 long block, I assume I can use all of my L-Jet. But I have questions: 1. Exhaust from my 1.8L will all fit and can stay, correct? I'm almost certain exhaust port spacing is the same on all engines for our cars. Sure 2. I would need new upper engine tins since the spark plug location is different. Yes 3. Do the rest of the tins from the 1.8L work? Yes 4. If I use 2.0L upper tins, did they have a stanchion to attach a fuel pressure regulator? Yes 5. I thought 1.8L FI runners have four bolts where they meet the head and 2.0L have three. Do I just drill the 1.8L runners for the third bolt (is there even room for that)? No get a set of 2.0L intakes if your long block is equipped with 2.0L heads 6. Are the lengths and positions of the L-Jet runners even compatible with the 2.0L? Sort of. there is some messing about youd need to do. Anything else I'm missing? Probably |
Van B |
Feb 5 2022, 04:12 PM
Senior Member Group: Members Posts: 1,586 Joined: 20-October 21 From: Maryland Member No.: 26,011 Region Association: None |
You’ll also need to follow the manuals procedures for tuning the AFM for the proper fuel trim. I think the L-Jet is pretty adaptable, but I would still recommend checking your mixture as the injectors for a 1.8 flow less than the 2.0.
nihil44 |
Feb 6 2022, 03:12 AM
Member Group: Members Posts: 157 Joined: 28-January 12 From: Brisbane, Australia Member No.: 14,058 Region Association: None |
If you use 3 stud 2.0 heads and 2.0 intake runners, the runners won’t line up with the 1.8 plenum. I cut the 2.0 3 stud runners and rewelded them to align with the 1.8 plenum. Not a difficult mod. I am in the process of ditching the D Jet on a 2.0 and installing LJet. Wish me luck
ClayPerrine |
Feb 7 2022, 06:52 AM
Life's been good to me so far..... Group: Admin Posts: 15,469 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Go find the crank and rods from a 2.0 VW Bus. There are lots out there.
Buy pistons and cylinders. Get your 1.8 Heads rebuilt with 2.0 Stainless valves. Find a Bus oversized throttle body. I will help you to put it together. Buy a Raby 9590 cam kit, including the pushrods, lifters and rocker spacers. The rest is just careful assembly. Clay |
swood |
Mar 27 2022, 09:31 PM
Senior Member Group: Members Posts: 1,839 Joined: 6-February 03 From: Strong Beach Member No.: 251 Region Association: None |
I’m just sorting through what i have to build my 2056 Ljet. Im presuming a 2.0L throttle body wouldn’t fit the 1.8L intake runners requiring use of the 2.0L ones with a bolt pattern needing modification. Sounds right? I’d like to stick with the Ljet at first anyways
ClayPerrine |
Mar 28 2022, 05:49 AM
I’m just sorting through what i have to build my 2056 Ljet. Im presuming a 2.0L throttle body wouldn’t fit the 1.8L intake runners requiring use of the 2.0L ones with a bolt pattern needing modification. Sounds right? I’d like to stick with the Ljet at first anyways You do not have to use 2.0 Heads for a 2056. The 1.8 heads work fine. Just have 2.0 valves put in them. Then get a Bus throttle body to make it breathe. The 2.0 throttle body won't fit on the 1.8L plenum, and you have to find a very rare air intake tube from a 912E to use it with the stock 2.0 plenum, and you have to change out the throttle switch assembly. Clay |
Lo-Fi Version | Time is now: 18th May 2024 - 12:33 PM |
