| Shredhead |
Feb 6 2022, 01:07 PM
Member ![]() ![]() Group: Members Posts: 115 Joined: 10-August 15 From: CT Member No.: 19,047 Region Association: North East States |
I need to pull mine in prep for painting. I've read everything I can and watched some videos, but I'm still confused regarding removing the trim. Other than cutting through any sealant/gunk, what do you need to do to free the trim from the clips (assuming they're still there)? Use a tool like Chris Foley's to push the trim off the clip?
| 914Mels |
Feb 7 2022, 02:44 PM
Member ![]() ![]() Group: Members Posts: 357 Joined: 20-June 11 From: Santee Member No.: 13,221 Region Association: Southern California |
A plastic trim tool works well, just run it under the trim and twist slightly at the clips. They will probably break so be prepared to pull the glass to replace them. If you find the trim glued down some fishing line can be used to "saw" thru the gunk.
| iankarr |
Feb 7 2022, 03:54 PM
The wrencher formerly known as Cuddy_K ![]() ![]() ![]() ![]() Group: Members Posts: 2,593 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region
If the glass is coming out (and why wouldn't it for a repaint (IMG:style_emoticons/default/wink.gif), the easiest way to remove the trim is to "chop" the clips using a very thin putty knife between the trim clip and the channel, directly over the pin which holds the clip to the body. A quick hit with a hammer and the plastic pin holding the clip breaks. Then you can lift the trim off as a single piece- clips and all. Remove the broken clips on the bench. Of course, you'll need to replace with new trim clips after paint and before the glass goes back in.
| PanelBilly |
Feb 7 2022, 03:55 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,948 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest
They’re going to break. Try not to bend up the trim.
| sportlicherFahrer |
Nothing to see here. ![]() ![]() ![]() Group: Members Posts: 1,124 Joined: 18-April 05 From: Tacoma, WA Member No.: 3,945 Region Association: Pacific Northwest
*edit* What Ian said. (IMG:style_emoticons/default/smash.gif)
| jims914 |
Feb 7 2022, 06:23 PM
Member ![]() ![]() Group: Members Posts: 140 Joined: 11-March 11 From: Tempe,AZ Member No.: 12,816 Region Association: Southwest Region
Make sure to use Porsche clips only or you will be sorry.
| rick 918-S |
Feb 7 2022, 08:31 PM
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,214 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region
I just slide a razor blade between the frame & the trim and cut the plastic clip. The trim is way to fragile to try to unhook the clips. Cut the clips and same the trim from bending.
| Shredhead |
Feb 8 2022, 07:45 AM
| Shredhead |
Feb 8 2022, 07:48 AM
If the glass is coming out (and why wouldn't it for a repaint (IMG:style_emoticons/default/wink.gif), the easiest way to remove the trim is to "chop" the clips using a very thin putty knife between the trim clip and the channel, directly over the pin which holds the clip to the body. A quick hit with a hammer and the plastic pin holding the clip breaks. Then you can lift the trim off as a single piece- clips and all. Remove the broken clips on the bench. Of course, you'll need to replace with new trim clips after paint and before the glass goes back in. Thanks Ian, and thanks for the video on how to reinstall it! |
| double-a |
Feb 8 2022, 11:14 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 989 Joined: 15-September 03 From: vancouver, wa, usa Member No.: 1,162 Region Association: Pacific Northwest |
to offer a counterpoint, i removed my windshield trim last night in preparation for paint, and was able to complete the job without wrecking any trim or breaking a single clip.
since i'm not replacing the glass, keeping the clips intact and undamaged was imperative. i used a plastic spudger and a 1.5" putty knife, and took it real slow. i started at the corner clips, easing them off carefully because they're made of butter. then i moved to the larger pieces, found where the trim-to-clip grip wasn't as strong, and worked out from there. if you need to do the job without damaging anything, it can be done. just be gentle and don't rush it. no matter how it goes for you, be excited about the fact that you can thoroughly clean the channel around the windshield. i was stunned by how much dirt, leaves, and other rust-attracting gunk had collected in the 15 years since i last had that trim off. (IMG:style_emoticons/default/barf.gif) if you're planning to r&r the windshield, do it right by cutting the old clips and using fresh ones, as others have recommended. either way, enjoy. working on these cars is a good time (most of the time). (IMG:style_emoticons/default/beer.gif) |
| Shredhead |
Feb 10 2022, 07:18 AM
to offer a counterpoint, i removed my windshield trim last night in preparation for paint, and was able to complete the job without wrecking any trim or breaking a single clip. since i'm not replacing the glass, keeping the clips intact and undamaged was imperative. i used a plastic spudger and a 1.5" putty knife, and took it real slow. i started at the corner clips, easing them off carefully because they're made of butter. then i moved to the larger pieces, found where the trim-to-clip grip wasn't as strong, and worked out from there. if you need to do the job without damaging anything, it can be done. just be gentle and don't rush it. no matter how it goes for you, be excited about the fact that you can thoroughly clean the channel around the windshield. i was stunned by how much dirt, leaves, and other rust-attracting gunk had collected in the 15 years since i last had that trim off. (IMG:style_emoticons/default/barf.gif) if you're planning to r&r the windshield, do it right by cutting the old clips and using fresh ones, as others have recommended. either way, enjoy. working on these cars is a good time (most of the time). (IMG:style_emoticons/default/beer.gif) Thanks. I do plan on re-using the windshield. I think some of not all of the clips may be missing already, but I'll find out soon. |
| jims914 |
Feb 10 2022, 08:52 AM
to offer a counterpoint, i removed my windshield trim last night in preparation for paint, and was able to complete the job without wrecking any trim or breaking a single clip. since i'm not replacing the glass, keeping the clips intact and undamaged was imperative. i used a plastic spudger and a 1.5" putty knife, and took it real slow. i started at the corner clips, easing them off carefully because they're made of butter. then i moved to the larger pieces, found where the trim-to-clip grip wasn't as strong, and worked out from there. if you need to do the job without damaging anything, it can be done. just be gentle and don't rush it. no matter how it goes for you, be excited about the fact that you can thoroughly clean the channel around the windshield. i was stunned by how much dirt, leaves, and other rust-attracting gunk had collected in the 15 years since i last had that trim off. (IMG:style_emoticons/default/barf.gif) if you're planning to r&r the windshield, do it right by cutting the old clips and using fresh ones, as others have recommended. either way, enjoy. working on these cars is a good time (most of the time). (IMG:style_emoticons/default/beer.gif) Thanks. I do plan on re-using the windshield. I think some of not all of the clips may be missing already, but I'll find out soon. Again use the PORSCHE clips. I had 10 out of 19 brake from 914R. |
Lo-Fi Version | Time is now: 3rd March 2026 - 01:39 PM |
