| jim dorociak |
Feb 6 2022, 06:45 PM
Member ![]() ![]() Group: Members Posts: 98 Joined: 23-January 09 From: Newbury Park, Ca Member No.: 9,966 Region Association: Southern California
guys I can see from inside the door where the holes go, but am looking for the proper way to drill down from the topside and get these holes right the first time.
Anybody have any ideas? Thanks! Jim |
| davep |
Feb 6 2022, 06:50 PM
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,359 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Use a center point tool with hammer to create a little dent from the inside of the nut. Drill an undersize hole then enlarge as needed.
| mepstein |
Feb 6 2022, 07:07 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,555 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
If you want to go from the outside in, the dimensions are the same as the driver side.
| windforfun |
Feb 6 2022, 07:19 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,095 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None
| jim dorociak |
Feb 6 2022, 07:35 PM
when you guys are talking about center punch going up, are you removing the door glass? Jim
| Shivers |
Feb 6 2022, 07:56 PM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,326 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
when you guys are talking about center punch going up, are you removing the door glass? Jim I just rolled the glass up and used a long punch. But like said already, if you are not comfortable with that, just measure from the drivers door and drill from the outside. Careful when drilling not to drill off the threads |
| jim dorociak |
Feb 6 2022, 08:55 PM
Thank you to all who replied. I will report back when holes are drilled. Jim
| vitamin914 |
Feb 7 2022, 06:29 AM
Member ![]() ![]() Group: Members Posts: 202 Joined: 8-September 21 From: Toronto Canada Member No.: 25,893 Region Association: Canada
Here is a how to article from Pelican Parts.
https://www.pelicanparts.com/techarticles/9...ight_mirror.htm |
| Front yard mechanic |
Feb 7 2022, 08:40 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,436 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None
| Cairo94507 |
Feb 7 2022, 10:51 AM
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,596 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California
I would suggest applying some tape to the exterior painted area where the mirror goes to protect the paint while you are drilling. Then remember to touch up the bare metal hole edges with some paint before you install the mirror.
| bkrantz |
Feb 7 2022, 08:58 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,633 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains
Rather than drill "fulll size" and risk the threads in the captive nuts, I made small pilot holes and then used a grinding bit in a Dremel to gradually enlarge the holes from the outside.
| ClayPerrine |
Feb 8 2022, 09:48 AM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,542 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
I just recently did this on the factory six. I had the correct early outside mirror, and both Betty and I like having a right hand mirror on the car. So I used a transfer punch from the inside to mark the center of the holes. Then I used the same punch to push the dimples back down. I used a "C" Drill bit to make the holes. You can use a 1/4 inch drill bit if you don't have a "C", but it will be a little bit bigger. I then chased the threads in the nut plate with a 6x1.0 tap, as they had never been used before.
Make sure to paint the holes before mounting the mirror. Gotta keep the tinworm at bay. Good Luck! |
| jim dorociak |
Feb 8 2022, 12:25 PM
Thanks everyone for the options on how to do this. I managed to punch from inside up the hole right by the window channel, then measured over to the front hole and drilled down. Even being slightly off I did not drill into the plate and then chased the threads down from the top side. It is done - great! - another small project off my list. Jim Dorociak
on to the rebuild of the 308 calipers and the 911 steering column and ignition switch - pretty sure these projects are more difficult. Still thinking of metal flares, but have not made my mind up yet. |
Lo-Fi Version | Time is now: 19th March 2026 - 07:41 PM |
