Relay Board |
Relay Board |
Puebloswatcop |
Feb 7 2022, 06:23 PM
Senior Member Group: Members Posts: 1,389 Joined: 27-December 14 From: Mineola, Texas Member No.: 18,258 Region Association: Southwest Region |
Can anyone tell me how they have soldered their relay board, without melting any of the plastic? I was thinking maybe silver solder, but the iron is still hot enough to melt the plastic, Any guidance would be appreciated.
914Sixer |
Feb 7 2022, 08:56 PM
You DO NOT need to solder the relay board. I have seen the copper eaten up but the rivets have never failed in any board I have done in the past 5 years. Be sure to hold the relay board up to a bright light. You will see ALL the holes you need to block (I use silicone) BEFORE pouring compound. Also take a square pencil eraser ($1 Store) and cut it into wedge to fit in square hole. Be sure and tape up across end with splits. You will also need tape on the screw holes where the voltage regulator mounts. Failure to do this and you will have compound running out all over the place.
Puebloswatcop |
Feb 8 2022, 06:59 AM
You DO NOT need to solder the relay board. I have seen the copper eaten up but the rivets have never failed in any board I have done in the past 5 years. Be sure to hold the relay board up to a bright light. You will see ALL the holes you need to block (I use silicone) BEFORE pouring compound. Also take a square pencil eraser ($1 Store) and cut it into wedge to fit in square hole. Be sure and tape up across end with splits. You will also need tape on the screw holes where the voltage regulator mounts. Failure to do this and you will have compound running out all over the place. Thanks for the tips Sixer, I have heard of some of the nightmare stories where people have poured the compound without plugging all of the holes, what a royal mess. Thanks also for the erasure idea, I was tryng to figure the best way to plug that hole. I have tested each and every lead and had good continuity throughout, so I guess they did do a pretty good job of riveting the leads together. Will post how it comes out. |
Feb 8 2022, 09:54 AM
Resident German Group: Admin Posts: 41,644 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Should be easy enough to check if any of the rivets are lose.
(IMG:style_emoticons/default/idea.gif) |
Shivers |
Feb 8 2022, 10:19 AM
Senior Member Group: Members Posts: 2,381 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
There are products like this. It cures at 250* F for an hour. I'm pretty sure the plastic would survive that. So if you find some high resistance or no contact at all, it might be worth a try.
https://conductivex.com/Silver-Mixed-Epoxy-...I8aAheKEALw_wcB |
walterolin |
Feb 8 2022, 11:09 AM
Senior Member Group: Members Posts: 685 Joined: 30-November 11 From: Louisville, Ky Member No.: 13,838 Region Association: South East States |
I you want to be sure, check the resistance on each circuit with a good DMM such as a Fluke 179.
914_teener |
Feb 8 2022, 05:26 PM
914 Guru Group: Members Posts: 5,198 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
You DO NOT need to solder the relay board. I have seen the copper eaten up but the rivets have never failed in any board I have done in the past 5 years. Be sure to hold the relay board up to a bright light. You will see ALL the holes you need to block (I use silicone) BEFORE pouring compound. Also take a square pencil eraser ($1 Store) and cut it into wedge to fit in square hole. Be sure and tape up across end with splits. You will also need tape on the screw holes where the voltage regulator mounts. Failure to do this and you will have compound running out all over the place. Thanks for the tips Sixer, I have heard of some of the nightmare stories where people have poured the compound without plugging all of the holes, what a royal mess. Thanks also for the erasure idea, I was tryng to figure the best way to plug that hole. I have tested each and every lead and had good continuity throughout, so I guess they did do a pretty good job of riveting the leads together. Will post how it comes out. I disagree. The rivets are of a different alloy if memory serves. Place the soldering iron on the rivet only and apply the solder to the trace near the rivet. BTDT. Use a very small iron and solder for electronics will do the trick. Use 50/50 solder if you can find it in a very small dia.....silver solder takes a much higher temperature so not necessary. I had loose rivets on mine and when hot they become more loose because of the Coeff of expansion on copper, particulary on the skiiny long traces for the fuel pump and the aux fan along the outside of the board. At a MINIMUM iI'd do those and ditto on making sure ALL the holes are plugged, you only get one chance with the di-electric epoxy. Good luck. |
Puebloswatcop |
Feb 8 2022, 06:01 PM
Thanks for your feedback guys. I have checked all the circuits and all of the rivits, they all checked good, just dont want to seal this thing up and then find out one decides to take a crap. Guess I will go ahead and seal it up when I return from my next trip.
Lo-Fi Version | Time is now: 18th May 2024 - 11:01 PM |
