QUOTE(Puebloswatcop @ Feb 8 2022, 04:59 AM)
QUOTE(914Sixer @ Feb 7 2022, 08:56 PM)
You DO NOT need to solder the relay board. I have seen the copper eaten up but the rivets have never failed in any board I have done in the past 5 years. Be sure to hold the relay board up to a bright light. You will see ALL the holes you need to block (I use silicone) BEFORE pouring compound. Also take a square pencil eraser ($1 Store) and cut it into wedge to fit in square hole. Be sure and tape up across end with splits. You will also need tape on the screw holes where the voltage regulator mounts. Failure to do this and you will have compound running out all over the place.
Thanks for the tips Sixer, I have heard of some of the nightmare stories where people have poured the compound without plugging all of the holes, what a royal mess. Thanks also for the erasure idea, I was tryng to figure the best way to plug that hole. I have tested each and every lead and had good continuity throughout, so I guess they did do a pretty good job of riveting the leads together. Will post how it comes out.
I disagree. The rivets are of a different alloy if memory serves. Place the soldering iron on the rivet only and apply the solder to the trace near the rivet. BTDT. Use a very small iron and solder for electronics will do the trick. Use 50/50 solder if you can find it in a very small dia.....silver solder takes a much higher temperature so not necessary.
I had loose rivets on mine and when hot they become more loose because of the Coeff of expansion on copper, particulary on the skiiny long traces for the fuel pump and the aux fan along the outside of the board. At a MINIMUM iI'd do those and ditto on making sure ALL the holes are plugged, you only get one chance with the di-electric epoxy.
Good luck.
