Steering column/rack refurb questions, What's wise to replace before reinstall of steering |
mgarrison |
Feb 8 2022, 01:44 PM
Member Group: Members Posts: 351 Joined: 14-February 20 From: Chandler, AZ Member No.: 23,922 Region Association: Southwest Region |
Hello,
I know opinions are like butts; everybody has at least one...but, I'm a bit confused about what to replace on my steering column & rack before reinstallation. Turbo tie rod upgrade - seems obvious. Rubber hockey puck replacement - seems obvious. I see some upper/lower bearings for the steering column listed on some vendors sites. But some only list one bearing, while others list multiple. Is there a consensus/recommendation on what should/is wise to replace while the whole thing is out? Thanks! |
Cairo94507 |
Feb 8 2022, 01:48 PM
Michael Group: Members Posts: 9,762 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
You have nailed it; and do both bearings for good measure. (IMG:style_emoticons/default/beerchug.gif)
mgarrison |
Feb 8 2022, 02:28 PM
Just found this thread via a Google search:
http://www.914world.com/bbs2/index.php?showtopic=350223 Looks like what I was after...I hope! |
mgarrison |
Feb 8 2022, 04:20 PM
914Sixer |
Feb 8 2022, 04:31 PM
You have the good upper bearing ring. Source the VW version not the stupid Porsche price. Added screen shot.
Attached thumbnail(s) |
mgarrison |
Feb 8 2022, 05:17 PM
Thanks - that's exactly what I did (IMG:style_emoticons/default/pray.gif)
76-914 |
Feb 8 2022, 10:13 PM
I'm glad you brought this up. It is right around the corner for my current resto of the 76. (IMG:style_emoticons/default/beerchug.gif)
mgarrison |
Mar 18 2022, 08:29 PM
So....Can someone share the "secret sauce", or voodoo, or just plain magic to get the upper column bearing over the corrugated metal sleeve around the steering shaft?
I destroyed the brand new bearing I had ordered trying to get it on there far enough for the snap ring to slot in place (IMG:style_emoticons/default/headbang.gif) Not a lot to go off of in the manual (IMG:style_emoticons/default/confused24.gif) Just wasted another $43 to get another one shipped out to me...shipping seems to be my kryptonite! (IMG:style_emoticons/default/hissyfit.gif) |
914Sixer |
Mar 18 2022, 08:41 PM
Get a piece of plastic pipe to fit outer diameter of bearing. Push bearing in with it.
mgarrison |
Mar 18 2022, 08:47 PM
mgarrison |
Mar 18 2022, 08:51 PM
On a side note, does anyone know what this bearing fits/is for? I thought it was the lower column bearing, but it's too large of a diameter. Unless it fits a 911/914-6 column...? RR called it "steering shaft support bearing".
Here's the numbers on it, not that my tired old eyes can really read them! |
GeorgeKopf |
Mar 18 2022, 11:27 PM
Member Group: Members Posts: 172 Joined: 9-February 21 From: Princeton, NJ Member No.: 25,186 Region Association: MidAtlantic Region |
So....Can someone share the "secret sauce", or voodoo, or just plain magic to get the upper column bearing over the corrugated metal sleeve around the steering shaft? I destroyed the brand new bearing I had ordered trying to get it on there far enough for the snap ring to slot in place (IMG:style_emoticons/default/headbang.gif) Not a lot to go off of in the manual (IMG:style_emoticons/default/confused24.gif) Just wasted another $43 to get another one shipped out to me...shipping seems to be my kryptonite! (IMG:style_emoticons/default/hissyfit.gif) @mgarrison Put the whole steering shaft and the sleeve in the freezer. Warm the bearing in the oven. Then use some assembly grease and a pvc pipe to press it on. |
Rob-O |
Mar 24 2022, 12:56 PM
Senior Member Group: Members Posts: 1,252 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region |
I think you remove the metal sleeve. If I remember correctly, that metal sleeve was an add-on part that was used when the inner plastic piece of the upper bearing failed (and they all failed). That metal sleeve took up the slop and made the steering wheel tight in the housing to help prevent the dreaded 914 steering wheel shake.
Lo-Fi Version | Time is now: 18th May 2024 - 02:07 PM |
