Another 914-6 GT Tribute Project |
Tom1394racing |
Feb 14 2022, 01:04 PM
Member Group: Members Posts: 283 Joined: 25-August 07 From: CT Member No.: 8,039 Region Association: North East States |
After having enjoyed several 911’s over the past 40 years, I decided about a year ago that my next project would be a 914-6 GT Tribute car. I had been thinking for some time about a mid-engine open car but the Boxster is just not my cup of tea. I am more of a 70’s air cooled hot rod type and I love my ’73 Signal Orange 911 RSR tribute car. So a 914-6 GT seemed like an obvious choice. It ticked all my boxes and I have always admired the ‘70’s GT race cars.
My friends at Auto Associates in Canton, CT knew I was considering a 914-6 GT project so when a customer’s ’73 914 2.0 became available there last fall we put it up on their lift, took a close look and deemed it an acceptable starting point. The project plan is to follow the same process I have used on my RSR and my ‘70E restoration projects. I strip the car in my home shop, send the shell to Auto Associates for the metal work, chassis stiffening and paint. The painted shell comes back to me and I do the mechanical work and reassembly. My plan is not to do a 100% accurate GT tribute but rather to build a car that looks, sounds and drives like a street friendly GT. I am not planning on any serious track or autocross but more of a fun spirited street hot rod. I know there is a ton of expertise and experience on this forum so I will be looking for some sage advice as I document the build in this thread. So here are my thoughts: Exterior GT flares front and rear. I will likely leave the decision of metal vs FG to Auto Associates. I would like the car to be as light as is practical. I have FG flares on my RSR and they have held up very well over the 15 years since the original restoration. I am also planning to do the lightweight, balsa reinforced front and rear trunk lids. I also would like to do the GT style double grill engine cover. Not sure if anyone makes these or if I will have Auto Associates fabricate one from my existing cover. I will go with the hood pins front and bungees rear for lid closure. Not sure whether to go with the motor operated headlights or if the cable operated system is reliable enough. I do not plan to do a lot of night driving. For wheels, I am thinking Minilites on the rear and Fuchs on the front. I also want to keep the removable top as open air driving is one of my key objectives. I am liking Mexico Blue for the color. Interior I plan to go with a 911 steering column and LHS 911 ignition switch as well as 911 turn signal, wiper switches and clamshell. I am also thinking of a reproduction 911 style hockey puck steering wheel. Door panels would be the GT style with strap operated pulls for door opening. I am also thinking of a pair of GTS Classic vintage seats perhaps the LeMans series. Gauges will mimic the GT type. Drivetrain I have a 3.0 L SC long block that I plan to use as a basis for power. I am thinking 9.5 CR with ModS type cams and a twin plug distributor. I am also toying with the idea of EFI. I am thinking 200-225 HP. I will stick with the 901 gearbox and the special 215 mm 9 bolt flywheel. I would use 911 output stubs, Sway Away free floating axles, and 911 stubs axles & hubs. I will use a front cooler and oil plumbing similar to the GT. Not sure which option to take with regard to the motor mounts. Suspension Other than 911 3.5” caliper spaced front struts, and 911 front hubs, I have not given the suspension much thought as yet. I do not want the car to be so stiff and jarring that it knocks my fillings out on the pothole strewn roads here in CT. That said, I also do not want the car to roll and lean like my stock ‘70E. I like the stock type of front and rear roll bars, maybe a little bigger than the stock size. I am thinking early 911S Aluminum calipers in the front. No sure about the rear calipers. I like the 15” Michelin TB’s for tires. Chassis Stiffening Like all 914’s this one is not rust free. After the rust repairs, I am planning to have Auto Associates install the chassis stiffening kits for the front torsion bar area, sills and rear suspension including the rear trailing arms. I am also planning on a weld-in roll bar with diagonals tied into the door sills that will allow for reasonably easy entry and exit. I want the chassis to be as stiff as possible yet still allow for the removable Targa roof. Well…That is the current plan. I am very interested in suggestions and input from those of you who have been down this road before me. I plan to post progress with photos as I go forward and I look forward to all your comments. |
ibmiked |
Apr 13 2022, 08:01 PM
Newbie Group: Members Posts: 41 Joined: 15-June 11 From: Brookhaven, Long Island Member No.: 13,198 Region Association: North East States |
Agreed, a roll bar is dangerous without a helmet. So too though is driving a 50 year old car that was designed and built before crumple zones and high strength steel in a world of 6,000lb SUVs driven by people whose attention is partially focused on their phones. We all accept a certain amount of risk when enjoying our cars.
mepstein |
Apr 13 2022, 08:33 PM
914-6 GT in waiting Group: Members Posts: 19,272 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Agreed, a roll bar is dangerous without a helmet. So too though is driving a 50 year old car that was designed and built before crumple zones and high strength steel in a world of 6,000lb SUVs driven by people whose attention is partially focused on their phones. We all accept a certain amount of risk when enjoying our cars. 914’s do have built in crumple zones. Why add something that’s proven to injure or kill you in an accident? |
ibmiked |
Apr 14 2022, 07:19 PM
Agreed, a roll bar is dangerous without a helmet. So too though is driving a 50 year old car that was designed and built before crumple zones and high strength steel in a world of 6,000lb SUVs driven by people whose attention is partially focused on their phones. We all accept a certain amount of risk when enjoying our cars. 914’s do have built in crumple zones. Why add something that’s proven to injure or kill you in an accident? Why ride a motorcycle? Or a bicycle on a public road? This kind of talk is silly. |
brant |
Apr 15 2022, 06:43 AM
914 Wizard Group: Members Posts: 11,624 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
[/quote] Why ride a motorcycle? Or a bicycle on a public road? This kind of talk is silly. [/quote] Nope A brain injury is not silly On a motorcycle you should also wear a helmet Just like a car with a roll cage Not silly Actually smart |
ClayPerrine |
Apr 15 2022, 09:23 AM
Life's been good to me so far..... Group: Admin Posts: 15,468 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
[quote name='brant' date='Apr 15 2022, 07:43 AM' post='2995390']
[/quote] Why ride a motorcycle? Or a bicycle on a public road? This kind of talk is silly. [/quote] Nope A brain injury is not silly On a motorcycle you should also wear a helmet Just like a car with a roll cage Not silly Actually smart [/quote] (IMG:style_emoticons/default/agree.gif) You are less likely to be hurt in an accident when not wearing a seat belt than you are getting into an accident on a motorcycle while not wearing a helmet, but we still have mandatory seat belt laws for cars. And you are way less likely to be hurt at an Autocross than you are when riding a motorcycle on the street. But we still wear helmets when running in an Autocross. Personally I think the people who get on a motorcycle in shorts, a wife beater t-shirt, flip flops, and sunglasses are stupid. And we as the general public have to support their long term medical care when they get squished by an 18 wheeler on the highway and somehow manage to live through it. (IMG:style_emoticons/default/mad.gif) My $.02.... To ride a motorcycle without a helmet should require you to sign a waiver stating that you agree that you or your family will pay all medical costs resulting from injuries that could have been prevented by wearing a helmet. Sorry.. this is one of my pet peeves. In Texas it is perfectly legal to ride a motorcycle without a helmet, but if you don't put your seat belt on in a car, you get a ticket. That is hypocrisy of the stupidest level. I am a seatbelt fanatic. They save lives. And when I did ride a motorcycle on the street, I wore a helmet. But I think they should either repeal the seatbelt law or re-instate the mandatory helmet law. I will get off my soap box now. Clay |
wonkipop |
Nov 1 2022, 07:51 PM
Advanced Member Group: Members Posts: 4,302 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
[quote name='ClayPerrine' date='Apr 15 2022, 09:23 AM' post='2995420']
[quote name='brant' date='Apr 15 2022, 07:43 AM' post='2995390'] [/quote] Why ride a motorcycle? Or a bicycle on a public road? This kind of talk is silly. [/quote] Nope A brain injury is not silly On a motorcycle you should also wear a helmet Just like a car with a roll cage Not silly Actually smart [/quote] (IMG:style_emoticons/default/agree.gif) You are less likely to be hurt in an accident when not wearing a seat belt than you are getting into an accident on a motorcycle while not wearing a helmet, but we still have mandatory seat belt laws for cars. And you are way less likely to be hurt at an Autocross than you are when riding a motorcycle on the street. But we still wear helmets when running in an Autocross. Personally I think the people who get on a motorcycle in shorts, a wife beater t-shirt, flip flops, and sunglasses are stupid. And we as the general public have to support their long term medical care when they get squished by an 18 wheeler on the highway and somehow manage to live through it. (IMG:style_emoticons/default/mad.gif) My $.02.... To ride a motorcycle without a helmet should require you to sign a waiver stating that you agree that you or your family will pay all medical costs resulting from injuries that could have been prevented by wearing a helmet. Sorry.. this is one of my pet peeves. In Texas it is perfectly legal to ride a motorcycle without a helmet, but if you don't put your seat belt on in a car, you get a ticket. That is hypocrisy of the stupidest level. I am a seatbelt fanatic. They save lives. And when I did ride a motorcycle on the street, I wore a helmet. But I think they should either repeal the seatbelt law or re-instate the mandatory helmet law. I will get off my soap box now. Clay [/quote] yep my business partner has been riding motorcycles for 40 years. high powered high end italian bikes. never gets on without full leathers, boots and full face. he has hit the deck several times. and has always gotten up intact! whenever i ride around in the car with him he is always commenting on the delicate asian university students getting about on motor scooters around here, in sandles, t shirts and non full face helmets. his standard remark, she might look pretty now, but she isn't going to be attractive with only half a jaw. (IMG:style_emoticons/default/sad.gif) i can still remember my time in chicago. guys on big harleys and gold wings would thunder past with no helmet and wearing a t shirt. on the interstate. used to blow my mind. not in a good way. seat belts are not even debated in australia. its been mandatory to have them and to have them on since the 1960s. no big deal. but each to his own i guess. i am surprised to hear its law in texas as i can still recall all the hoo haa in the USA in the late 80s over compulsory seat belt laws. as far as i can remember you guys did not have those laws back then. i remember the cars with those wacko auto seat belts that ran on tracks around the heads of the doors. i laughed every time i got in a car with those things. you need to pad cages inside a car. even on the track. at least down here. no such thing as an unpadded roll cage in this neck of the woods. street or track. |
Lo-Fi Version | Time is now: 18th May 2024 - 01:31 AM |
