Refinishing Fuch Alloy Wheel Bolts, What to do and who does it? |
jagalyn |
Feb 19 2022, 06:59 AM
True Patina Group: Members Posts: 414 Joined: 31-January 06 From: Scandia, MN Member No.: 5,503 Region Association: None |
What should I be looking for? Clear Zinc Plating? Should the bolts be wire brushed or blasted prior to plating? What company would you recommend for the plating? Thanks for your help. |
914Sixer |
Feb 19 2022, 07:22 AM
914 Guru Group: Members Posts: 8,892 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Some of the bolts were chromed and some were clear zinc plated. I use a wire wheel and clean them up as much as possible. I use a flat file and fix any edges that need to be flattened. My chrome guy gets $5 a bolt.
bdstone914 |
Feb 19 2022, 11:42 AM
bdstone914 Group: Members Posts: 4,527 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I have always had them clear zinc plated. Wire wheel the threads to get them clean and smooth.
Aerostatwv |
Feb 19 2022, 01:51 PM
Member Group: Members Posts: 117 Joined: 13-July 11 From: WV Member No.: 13,315 Region Association: MidAtlantic Region |
Lo-Fi Version | Time is now: 26th May 2024 - 01:48 PM |
