jagalyn
Feb 19 2022, 06:59 AM
Refinishing Fuch Alloy Wheel Bolts
What should I be looking for? Clear Zinc Plating? Should the bolts be wire brushed or blasted prior to plating?
What company would you recommend for the plating?
Thanks for your help.
914Sixer
Feb 19 2022, 07:22 AM
Some of the bolts were chromed and some were clear zinc plated. I use a wire wheel and clean them up as much as possible. I use a flat file and fix any edges that need to be flattened. My chrome guy gets $5 a bolt.
bdstone914
Feb 19 2022, 11:42 AM
I have always had them clear zinc plated. Wire wheel the threads to get them clean and smooth.
Aerostatwv
Feb 19 2022, 01:51 PM
I used the Caswell process to blue chromate this lug bolt. I wire brushed them clean but you need to follow the Caswell process to remove the old plating before you can apply the new plating. I thought they came out great.
Cheers,
Chris
Click to view attachment Click to view attachment
