defroster vent removal SOLVED, defroster vent seal |
Medtner3 |
Feb 19 2022, 10:31 AM
Member Group: Members Posts: 180 Joined: 7-July 20 From: Cedar Park Member No.: 24,467 Region Association: None |
How do you remove the left and right dash defrosters? I need to replace the seals. I took the bolts out underneath and removed two snap rings from the vent (breaking plastic in the process ... hopefully be able to glue that back or epoxy)
But it's loose doesn't want to come out Edit: the passenger side did come out by wiggling it around it was a very very tight fit the drivers side was super easy |
Lo-Fi Version | Time is now: 19th May 2024 - 02:22 AM |
