How do you remove the left and right dash defrosters? I need to replace the seals. I took the bolts out underneath and removed two snap rings from the vent (breaking plastic in the process ... hopefully be able to glue that back or epoxy)
But it's loose doesn't want to come out
Edit: the passenger side did come out by wiggling it around it was a very very tight fit the drivers side was super easy
