D1A3 |
Gruppe Neun Vierzehn Südosten ![]() ![]() Group: Members Posts: 362 Joined: 3-June 04 From: Atlanta, GA Member No.: 2,152 Region Association: South East States ![]() |
Hi everyone,
I got my 2.0 engine back from a rebuild and have been workign this weekend to get it up and running. The question I have is regardign the EFI harness. It's obvious which 4 connectors go to the injectors, but what is less obvious is if it matters which harness connector goes on which injector on each side of the engine. I found that it also does not matter which way you plug the harness into the injectors either. I'm hoping for some clarification before I connect my gas lines back up and try to start the car (and create any poblems!). Also, on the drivers side of the engine, one of the connectors has a white rubber covering, wheras the others all have black. I put the white one on #1, assuming it was correct. Any guidance is MUCH appreciated. --Jason |
Lo-Fi Version | Time is now: 14th July 2025 - 08:36 PM |
