Oil cooler in engine compartment, Anyone used a Mesa Plate cooler |
StratPlayer |
Jul 24 2003, 01:57 PM
StratPlayer Group: Members Posts: 3,278 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
No its a 4,, 76 2.0
Mark Henry |
Jul 24 2003, 02:09 PM
Stratplayer, where and how much for the Mocal (IMG:style_emoticons/default/icon14.gif)
PP's price seems a tad high. |
StratPlayer |
Jul 24 2003, 02:12 PM
Cheapest I could find was from Performance Products, $119.00 + shipping. I think Pelican wanted 124 for the same thing.
J P Stein |
Jul 24 2003, 02:19 PM
I mounted the thermo near the motor......why?
It's a bit easier on the oil pump. With the thermo in the front, the oil pump has to push cold oil thru 15-20 feet of oil line to return it to the tank....with resultant higher back pressure.....vs 6-8 feet for the set-up near the engine. I'm not a big fan of the Mocal thermo either. The pressure relief in the Troutman thermo saved my motor from my stupidity. The Mocal doesn't have this feature. |
seanery |
Jul 24 2003, 02:43 PM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
What's wrong with running this thermo on a -6?
MJHanna |
Jul 24 2003, 03:05 PM
Does this 911 make my butt look big? Group: Members Posts: 805 Joined: 23-January 03 From: Lowry Crossing, Texas Member No.: 185 |
: http://www.rennsportsystems.com
"A related issue is the oil thermostat. The Factory-style oil thermostat is a very special device. This regulates oil pressure, as well as oil temperature, to and from, the front auxiliary oil cooler. The pressure relief function of the Factory thermostat ensures that the inlet side of the oil pump is never starved due to the pressure drop in the long lines to the front cooler. Aftermarket oil thermostats such as the Mocal unit do not have this feature and you risk starving the engine of oil pressure during peak pressure demands. We strongly recommend only using the Porsche thermostat or the Troutman thermostat since they both have the same internal architecture and use the same Behr element." |
seanery |
Jul 24 2003, 03:09 PM
GOOD INFO!
efrenv |
Jul 24 2003, 03:31 PM
Newbie Group: Members Posts: 35 Joined: 11-February 03 From: Claremont, California Member No.: 297 |
Brad,
I can take a picture and post it. Yes, I met Don Haney at Pelican Parts. Really cool guy, helped me at PP when I was buying parts there. Nice red 911 too. Have to attend one of their swapmeets one of these days. (IMG:style_emoticons/default/wink.gif) Efren |
efrenv |
Jul 24 2003, 09:04 PM
Here is a photo of the Setrab Oil cooler in the A/C compressor compartment.
Attached thumbnail(s) |
Brad Roberts |
Jul 24 2003, 11:56 PM
Wow.. packed it in tight. Kept the lines short though.
B |
brant |
Jul 25 2003, 08:41 AM
914 Wizard Group: Members Posts: 11,632 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I've seen one engine oil cooler I liked..... not the most aerodynamic solution... but cheaper and effective...
A local guy rigged a cooler in the engine bay. It clipped onto the inside of the engine lid for street purposes.. (yes, hot air in the intake).. but the lines were a little longer than that.. when he showed up at Drivers ed. events, he had rigged a mount to screw in to the factory ski rack holes under the targa bar. The cooler popped out of the engine bay and attatched to this mount... Basically standing up above the roof. Full air flow.. not aerodynamic, but full air flow with short lines. brant |
Aaron Cox |
Jul 25 2003, 09:35 AM
what if one were to do a 'corvair' style trunk lid. put louvers/scoops and mount the cooler back there. the air would have to exit somewhere.......(just thinking outloud)
brant |
Jul 25 2003, 09:40 AM
lots of people do...
but full frontal air is still better. brant |
Brad Roberts |
Jul 25 2003, 10:56 AM
They exit the air in between the rear tailights when the coolers are mounted in the trunk.
B |
makinson1 |
Aug 28 2003, 09:08 AM
Member Group: Members Posts: 50 Joined: 13-August 03 From: Tallahassee, Fl Member No.: 1,021 |
Where do I get the sandwich adapter ? how do I get air to the upfront cooler when there are no holes in my 74 SE Air Dam ? Can I use the coiled copper tubing from my bourbon still to cool the oil?
Pnambic |
Aug 28 2003, 09:33 AM
Honk if you like obscene gestures! Group: Members Posts: 914 Joined: 9-April 03 From: Atlanta, GA Member No.: 546 Region Association: South East States |
Maybe a stupid question, but I've been called stupid more than once, so it doesn't hurt so bad anymore. When woud you say you need to invest in one of these oil coolers? I figure in a stock 1.7 that its probably not worth the effort. When does it become worthwhile or perhaps necessary?
(IMG:style_emoticons/default/huh.gif) |
ArtechnikA |
Aug 28 2003, 09:36 AM
QUOTE(Pnambic @ Aug 28 2003, 07:33 AM) When does it become worthwhile or perhaps necessary? when your oil temp exceeds 230F in the service it is intended for. |
Pnambic |
Aug 28 2003, 11:00 AM
Imagine the oil cooler you could stick on this baby! (IMG:style_emoticons/default/lol3.gif)
makinson1 |
Aug 28 2003, 11:17 AM
Do I really need an extra cooler? At ~80mph on the Freeway, motor turns about 3200 rpm, and oil temp guage is about 3/4 way up.
Aug 28 2003, 12:35 PM
914 Idiot Group: Members Posts: 14,991 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
QUOTE(efrenv @ Jul 24 2003, 01:31 PM) Yes, I met Don Haney at Pelican Parts. Really cool guy, helped me at PP when I was buying parts there. Sadly, Don is no longer working at Pelican. I don't think he even has anything to do with the D&G swap meets any more. (IMG:style_emoticons/default/sad.gif) --DD |
Lo-Fi Version | Time is now: 3rd June 2024 - 01:35 PM |
