Wheel clearance question on GT body |
sixaddict |
Mar 2 2022, 12:49 PM
Senior Member Group: Members Posts: 800 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States |
Trying to determine wheel fitment on a GT for best clearance
Currently running 9 x 16 Fuchs with Hoosier R7 245 x 45…..have some rubbing but mainly cleared it but very close on the inside. Was fine with R6 but 7 (IMG:style_emoticons/default/idea.gif) If We switch to 8 x 16 would it increase clearance. |
914 Ranch |
Mar 3 2022, 03:42 PM
Team Sharp where the 914 grow wings Group: Members Posts: 1,410 Joined: 29-January 16 From: TheNorth Shore Retreat. Deland Member No.: 19,611 Region Association: South East States |
Depends on the offset, I have more clearance on the outside than the inside fender well. Spacers made it even better. But it still keeps a little spot polished.
sixnotfour |
Mar 5 2022, 03:17 PM
914 Wizard Group: Members Posts: 10,418 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
offset and flair install ...Fuchs offset chart..
Attached image(s) |
Shivers |
Mar 6 2022, 03:39 AM
Senior Member Group: Members Posts: 2,365 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
mlindner |
Apr 10 2022, 07:08 AM
Senior Member Group: Members Posts: 1,515 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
8's squared should work fine. I run the standard 7 & 8s with 1/2 spacers in front and all the clearances are fine.
CCE |
May 7 2022, 08:19 PM
CCE Group: Members Posts: 309 Joined: 28-December 21 From: Mexico Member No.: 26,203 Region Association: NineFourteenerVille |
Is there a chart like that for a narrow body?
infraredcalvin |
May 9 2022, 07:52 PM
Distracted Member Group: Members Posts: 1,510 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California |
That is not a chart for the body, it’s for the wheel, Fuchs specifically. Measure distance from hub to inside fender, compare to chart by subtracting backspace from wheel width and that’ll give you an idea of how wide of Fuchs you can run.
There is much more to it, but it’s a starting point. |
PlaysWithCars |
Aug 10 2022, 10:36 PM
Senior Member Group: Members Posts: 524 Joined: 9-November 03 From: Southeast of Seattle Member No.: 1,323 Region Association: Pacific Northwest |
I'm running 8x15 at all four corners w/ 245 A7s. Slight rub on the rear inside w/ ~2.0 deg negative camber. Tight to the fender lip, but don't draw any conclusions from that. My car has fiberglass flares that are not consistent left to right.
NARP74 |
Oct 5 2022, 04:58 PM
Senior Member Group: Members Posts: 1,056 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
Is there an update to the chart that has the 951 7 x 16s on it? Or are they the same as the 911 7 x 16s?
Lo-Fi Version | Time is now: 3rd May 2024 - 02:12 AM |
