Factory Dash tops update post #110 $340 for late, New dash tops like OEM |
Mikey914 |
Mar 9 2022, 05:42 PM
The rubber man Group: Members Posts: 12,639 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
We have been making the solid rubber dash tops for many years now and yes they will not crack, but the materials costs have gone up significantly. We are doing our best to hold our prices down, but we will have to raise them eventually (Currently $650 full retail).
The way the factory made the OEM dashes is MUCH cheaper. It uses a less dense foam (that also is not self skinning) and has the vinyl stretched over the low density foam. This is why they all crack at the same points. We have already committed to making the tooling and have a projected release date of late July early August. We are projecting that we can sell these full retail at $495, and like always we will do a group buy with a significant discount. While I hate to throw this out there before we have everything worked out I felt it important to note that there are pending. I know George always says this is such a small market to make parts for that 2 people making the same parts makes it more difficult, but you the consumer will benefit here. Significantly. So with the knowledge that these are forth coming I'm posting and if you are interested (we are looking in the low $300 range for these). Let me know here. Like always if I can do better I do pass it on. Thanks all (IMG:style_emoticons/default/biggrin.gif) PS We will have the solid rubber re run in about 20 days. We are currently doing them up now. It's unfortunately why we had to raise the retail to $650 as the material went up again. Attached image(s) |
StarBear |
Mar 9 2022, 06:27 PM
Senior Member Group: Members Posts: 1,852 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States |
Thanks! So good to have choices.
NARP74 |
Mar 9 2022, 06:46 PM
Senior Member Group: Members Posts: 1,051 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
Mine is cracked, you've got my money.
mepstein |
Mar 9 2022, 06:47 PM
914-6 GT in waiting Group: Members Posts: 19,244 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I’ll take two. Thanks
emerygt350 |
Mar 9 2022, 07:11 PM
Advanced Member Group: Members Posts: 2,080 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
How would you judge installation difficulty with this new one? Same, different?
sixaddict |
Mar 9 2022, 07:37 PM
Senior Member Group: Members Posts: 799 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States |
Mark
I am in for one Thank you ! |
Tom1394racing |
Mar 9 2022, 08:19 PM
Member Group: Members Posts: 274 Joined: 25-August 07 From: CT Member No.: 8,039 Region Association: North East States |
I will take one
windforfun |
Mar 9 2022, 08:49 PM
Senior Member Group: Members Posts: 1,776 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
"The way the factory made the OEM dashes is MUCH cheaper. It uses a less dense foam (that also is not self skinning) and has the vinyl stretched over the low density foam. This is why they all crack at the same points."
My dash is original & it hasn't cracked yet. (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) |
Cornerlot |
Mar 9 2022, 08:53 PM
Member Group: Members Posts: 88 Joined: 4-June 16 From: New Braunfels, TX Member No.: 20,070 Region Association: Southwest Region |
Put me down for one.
Shivers |
Mar 9 2022, 10:18 PM
Senior Member Group: Members Posts: 2,357 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
Only way I could afford one. Thanks Mikey
wonkipop |
Mar 9 2022, 10:38 PM
Advanced Member Group: Members Posts: 4,250 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
"The way the factory made the OEM dashes is MUCH cheaper. It uses a less dense foam (that also is not self skinning) and has the vinyl stretched over the low density foam. This is why they all crack at the same points." My dash is original & it hasn't cracked yet. (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) thats because you live in "off the map"? - a place where the sun does not shine? ------ 30 years ago all the cars that came in to aus from cali had cracked dashes even then. i had a car from chicago - no cracks in dash. i think they called that spot of light in the sky that shone through the white haze in summer the sun. i'm fairly sure they were mistaken and it was venus magnified by humidity. |
Shivers |
Mar 9 2022, 10:52 PM
"The way the factory made the OEM dashes is MUCH cheaper. It uses a less dense foam (that also is not self skinning) and has the vinyl stretched over the low density foam. This is why they all crack at the same points." My dash is original & it hasn't cracked yet. (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) thats because you live in "off the map"? - a place where the sun does not shine? ------ 30 years ago all the cars that came in to aus from cali had cracked dashes even then. i had a car from chicago - no cracks in dash. i think they called that spot of light in the sky that shone through the white haze in summer the sun. i'm fairly sure they were mistaken and it was venus magnified by humidity. When I got mine in 1982 the dash was cracked. I bought a dash cover. But I do live under the sun. |
hndyhrr |
Mar 9 2022, 11:14 PM
Senior Member Group: Members Posts: 554 Joined: 1-September 13 From: central point,oregon Member No.: 16,332 Region Association: Pacific Northwest |
Put me down for one please
porbmw |
Mar 9 2022, 11:26 PM
Senior Member Group: Members Posts: 811 Joined: 10-September 08 From: Vancouver, B.C. Member No.: 9,534 Region Association: None |
Dang, they look great!
BUT there is an even smaller market looking for help....the "early version" Would you be able to do them, with the slight modifications required. (IMG:style_emoticons/default/beerchug.gif) |
Montreal914 |
Mar 10 2022, 12:35 AM
Senior Member Group: Members Posts: 1,541 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
From unobtanium crack free dash cover a few years ago to three new offerings now? (IMG:style_emoticons/default/blink.gif)
- 914rubber, rubber dash - 914rubber, OEM like dash - and this one? http://www.914world.com/bbs2/index.php?showtopic=358616 We need more 914s... (IMG:style_emoticons/default/smile.gif) |
DaveB |
Mar 10 2022, 01:25 AM
Member Group: Members Posts: 163 Joined: 25-November 21 From: Portland, Oregon Member No.: 26,107 Region Association: Pacific Northwest |
Great timing, just starting to tear my dash out. Count me in for one. BTW - lower dash knee pad would help too (lol).
Thanks!!! DaveB |
jettonjoshua |
Mar 10 2022, 02:08 AM
Newbie Group: Members Posts: 14 Joined: 25-February 08 From: SF Bay Area Member No.: 8,748 Region Association: Northern California |
I’m definitely in for one.
wonkipop |
Mar 10 2022, 03:40 AM
Dang, they look great! BUT there is an even smaller market looking for help....the "early version" Would you be able to do them, with the slight modifications required. (IMG:style_emoticons/default/beerchug.gif) no - there is an even smaller market. rhd 914s. but its too late to save us. i don't think our dashes down here crack - being fibreglass simulacrums. (i used a bigger word than @Emerygt350 ? - its your fault i learned it in america). fibreglass then skinned in vinyl. a bit like the old 911 dashboard tops. this dash project of 914 rubber is i think seriously good. i've never heard of anyone reproducing dashboards like this except some dude in south africa who started making them for VW type 3s. he is probably dead now. they were rhd too and he got flooded with demands from the USA for mirror versions. good work by 914 rubber. buy em. (IMG:style_emoticons/default/beerchug.gif) but ---------? remember. keep it out of the sun. VW type3 dashboards exploded in australia while the cars were still under warranty. like - 6 months out of the showroom. |
Mikey914 |
Mar 10 2022, 08:05 AM
How would you judge installation difficulty with this new one? Same, different? Id put them as the same effort. The attachment points are still a pain to get to either way. When I mentioned they are destined to crack, it is more of a commentary on the built in design flaws. Mainly that the low density foam has a different density than the top vinyl. Being black it will absorb a significant amount of heat, and at a different rate of expansion than the substrate. Over time this becomes fatiguing to the surface material. It’s not a matter of UV degradation, but differences in density of material. This is proven in that they all crack in the same points where stress is concentrated. Yes it is possible to have a OEM dash not cracked, but it would be because the dash hasn’t been through these cycles as often. Dash covers are a good way to protect them, and I may just start making a one to sell with. |
akp2002 |
Mar 10 2022, 09:54 AM
Member Group: Members Posts: 95 Joined: 11-January 21 From: Massachusetts Member No.: 25,059 Region Association: North East States |
Please put me down for one also!
Lo-Fi Version | Time is now: 29th April 2024 - 08:53 AM |
