FS:, 1970 914/6 matching |
914/6packer |
Mar 11 2022, 11:55 PM
I'm new here ... Group: Retired Members Posts: 0 Joined: 4-August 11 From: Colorado Member No.: 13,396 Region Association: Rocky Mountains |
ADMIN EDIT
Scammer: Peter Johantgen Estes Park, Colorado Primarily deals with 914 and 912 parts Mostly sells on the Samba, eBay "356bb246" Pelican "914/6packer" Peterjobuzz@yahoo.com 1970 914/6 Porsche, modified. Price: $90,000 This 914/6 was purchased from Dr. Sam Wang in 1978 in California. The motor was modified in 1976 by Peter Zimmermann the owner of Red Line Porsche in Santa Monica. The original 2.0 six was converted to a 2.4S (2.4 crank, 2.4 rods, 2.2 S P's & C's with S distributor. 1983 the gearbox was converted to an LSD side shifter, also front adjust sway-bar thru chassis under gas tank. 1986 GT oil cooler installed using aero quip thru the rocker panels, a factory thermostat and re-routing all lines to and from motor with aero quip (this is not using a sandwich plate on the oil filter, this is the proper way to add the oil cooler. The car was up-dated at 109,700 miles: 1. New dash. 2. Reinforced chassis trailing arm mounts. 3. Reinforced wheel well mounts. 4. Moved battery to right front trunk. 5. Installed battery cut-off switch in engine compartment. 6. Installed a 911 8000 RPM tach and oit temp/pressure gauge. 7. Installed 911 S brakes and 1985 Carrera rears with braided brake lines. 8. New rear wheel bearings. 9. Installed turbo tie rods. 10. New Momo steering wheel. 11. Motor: Completely rebuilt by Chris Powell in Bellevue, Washington, former Chief Mechanic for Bruce Leven's 935's & 962's race team. Chris's German Auto. a. New main Bearings b. New rod bearings c. New oil pump d. New rod bolts e. New 2.2 "S" P's & C's f. Complete head & valve work including race springs g. Re-ground cams to E sport h. Carrera valve covers i. New S clutch, pressure plate & throw-out bearing j. Installed HPV-1 Electromotive Crank-fire ignition system k. New updated cam tensioners to late hydraulics l. New Moroso (high temp - high voltage) spark plug wires m. New Webber 40 IDA Carbs n. New K&N filters o. Installed New European GEORGE headers Matching Numbers. Increased HP 2.4 S with E sport cams. @ 2.4 crank 2.4 rods, 2.2S P&C's, built by Chris Powell, Bellevue WA. Gearbox converted to side shifter and LSD (Limited Slip). GT oil cooler aero-quip with fac.thermostat front of car, proper way. New dash, reinforced trailing arms & wheel well mounts. 911S aluminum & Carrera brakes. Tub, zero rust on chassis, garaged. Three owner's from new. Original Tool kit, books and receipts. Mileage: 113,725 Exterior Color: White Interior Color: Black Tub: ZERO RUST, GARAGED ALL OWNERS Paint condition: Small dent on hood, some nicks and scratches. Motor condition, Very Good. No leaks. |
Cairo94507 |
Mar 12 2022, 08:47 AM
Michael Group: Members Posts: 9,752 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Please post pictures of the car and if possible a video of it running. (IMG:style_emoticons/default/welcome.png)
mtndawg |
Mar 12 2022, 03:48 PM
Member Group: Members Posts: 414 Joined: 26-January 09 From: Granite Bay, Ca Member No.: 9,985 Region Association: None |
How do you have a price tag of 90k and no photos?
BENBRO02 |
Mar 12 2022, 04:12 PM
Member Group: Members Posts: 481 Joined: 6-March 15 From: Nokesville, Virginia Member No.: 18,493 Region Association: MidAtlantic Region |
gcrotvik |
Mar 12 2022, 09:29 PM
Member Group: Members Posts: 360 Joined: 16-December 09 From: Portland Oregon Member No.: 11,134 Region Association: Pacific Northwest |
Seller has 0 posts. Maybe new to the World, maybe not...
gcrotvik |
Mar 12 2022, 09:33 PM
A quick search of "Sam Wang 914-6" brings up these posts:
http://smclassiccars.com/porsche/646056-19...6-matching.html http://www.tvsonline.net/dfink/914/ Price - $29,995 https://www.etsy.com/listing/708759892/pors...see-ad-for-info |
MM1 |
Mar 13 2022, 10:45 PM
914 obsession continues Group: Members Posts: 608 Joined: 9-May 18 From: Thousand Oaks, CA Member No.: 22,105 Region Association: Southern California |
So 30k price increased to 90k?
What new items/rebuilds are factored into the increase? |
Craigers17 |
Mar 14 2022, 05:32 AM
Senior Member Group: Members Posts: 733 Joined: 5-August 17 From: Rome, GA Member No.: 21,317 Region Association: South East States |
First off, let me start by saying that I'm NOT advocating for this seller, or even saying he's legit. I would like to know what we are calling a Scammer. Are we saying this guy isn't real? Are we agreeing he is real, but doesn't have the merchandise he claims to? Are we saying he's a difficult guy to deal with? Are we saying that he is asking way to much for cars he does own and is trying to sell? Or are we saying that he is real, but his identity has been stolen and someone else is trying to pass themselves off as him in order to scam people?
Sadly, people are buying 914's all the time now and reselling them for outrageous prices. Am I ever going to pay $90K for a Porsche 914? Hell no, but you see it all the time on BAT. Personally, I BELIEVE, this guy is real and does have(or at least did have) the cars he purports to have. I think we have members here in North Carolina that can at least vouch for him being a real person and having many 914's....at least at one time. I THINK he used to be in the same area as John Forbes, @Naro914 , etc. Then again, maybe I have him confused with someone else. At any rate, I THINK he is the guy selling this car on EBAY right now. Due Diligence should be done to 100% verify this information, but it looks like the same guy. https://www.ebay.com/itm/384749332030?hash=...lAAAOSwWTxiFWg8 I'm not trying to be a dick here, or imply that this is the guy that I would by my next 914 from. I'm just trying to figure out why he has been labeled a Scammer. All this being said, I have the utmost respect for our Admins, and generally trust their judgement....it's like being an I.T. Director.....no one ever thanks you when everything is working fine, but he's the first one to hear about it when someone's computer has the smallest glitch. |
Mar 15 2022, 09:48 AM
I would like to know what we are calling a Scammer. @Craigers17 A quick search on google reveals that he has a history of scamming people out of their money. Not sure what else you need? Also not sure why you are promoting him by adding additional links to things he's selling elsewhere? (IMG:style_emoticons/default/confused24.gif) |
MM1 |
Mar 15 2022, 05:01 PM
Thank you, as always, Andy.
I don’t need to know if this person is a scammer, in order to believe that there’s a “special” place - somewhere near the 9th circle of Dante’s Inferno for all who are . . .scammers. To them, I say, have “fun” next to this one (IMG:style_emoticons/default/devil.gif) |
davep |
Apr 28 2023, 08:05 AM
914 Historian Group: Benefactors Posts: 5,141 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Currently on eBay selling a Deposit on the car; no wonder it smells like a scam
VIN: 9140432040 https://www.ebay.com/itm/115782287272?_trkp...675.c101224.m-1 |
930cabman |
Apr 28 2023, 08:55 AM
Advanced Member Group: Members Posts: 3,058 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
If it smells like a _______ (you fill in the blank), it probably is a _______
ranger |
May 2 2023, 08:01 AM
Newbie Group: Members Posts: 18 Joined: 21-November 10 From: North Carolina Member No.: 12,409 Region Association: South East States |
I know Peter,he was a friend of a friend, thats how I meet him, and yes
he knew everyone in the Denver NC Click.He wanted to see my creamcicle while at my shop,he asked to take a pic of the car,I said ok, did'nt think anythink of it. a week or two l ater I see the pic of my car on Ebay Peter was using the pic of my car to sell his creamcicle. after a very direct email my car pic was taken off Ebay..... I don't trust him, I personally would not do any business with him. I'm Ranger on 914 world, and RIX914 parts in the other world....... |
Front yard mechanic |
May 2 2023, 05:40 PM
Senior Member Group: Members Posts: 1,162 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None |
Sam wang (IMG:style_emoticons/default/lol-2.gif)
Mike Fitton |
May 3 2023, 08:56 AM
Senior Member Group: Members Posts: 609 Joined: 13-May 11 From: Chicago Area Member No.: 13,069 Region Association: Upper MidWest |
^^^^Wasn't he in Caddy Shack? |
rhodyguy |
May 3 2023, 09:55 AM
The eBay ad is the weirdest one I’ve seen. Not quite sure what it means. A non refundable deposit? Is this to secure the right to bid on the car? Grifters warrant a long rope. Much suckage on EBay.
flat4guy |
May 3 2023, 08:49 PM
Member Group: Members Posts: 442 Joined: 10-October 16 From: nor cal Member No.: 20,484 Region Association: Northern California |
actually says NONE refundable. haha
davep |
Jul 18 2023, 08:07 AM
Now on The Samba:
https://www.thesamba.com/vw/classifieds/det....php?id=2576325 |
Retroracer |
Jul 19 2023, 09:17 AM
Senior Member Group: Members Posts: 612 Joined: 7-July 13 From: Bend OR Member No.: 16,100 Region Association: Pacific Northwest |
"Cash, silver, bank transfer." I often pay for all my groceries in pieces of silver. Some places are funny about accepting it though. - Tony |
Bullethead |
Jul 19 2023, 02:37 PM
Oil Cooled heart Group: Members Posts: 897 Joined: 24-June 10 From: South Florida Member No.: 11,875 Region Association: South East States |
Currently on eBay selling a Deposit on the car; no wonder it smells like a scam VIN: 9140432040 https://www.ebay.com/itm/115782287272?_trkp...675.c101224.m-1 And the service booklet has the VIN 9140431855. Clever, this one. |
Lo-Fi Version | Time is now: 15th May 2024 - 04:52 AM |
