Fuel Leak- Injectors 1975 2.0 |
creeves84 |
Mar 12 2022, 05:40 PM
Newbie Group: Members Posts: 7 Joined: 10-April 20 From: mn Member No.: 24,121 Region Association: Upper MidWest |
I have two issues with my 75 2.0 stock F.I. system. The first is the harness, its brittle and I have one on order with Jeff Bowlsby. The car loads up and all the connectors are suspect, so I know that needs to be replaced.
The other issue is a fuel leak- I thought it was a seal or injector, so I replaced all the seals and 4 new injectors. Now when I start the car, no leaks, then after a minute running, it starts leaking just below the injector. I can't see where from but it's a decent leak. Just cyl 2 and not always does it leak. I removed, reseated the injector and it was fine for another minute, then leaked again. Could it be a bad pressure regulator? What am I missing? |
Lo-Fi Version | Time is now: 18th May 2024 - 12:21 PM |
