I have two issues with my 75 2.0 stock F.I. system. The first is the harness, its brittle and I have one on order with Jeff Bowlsby. The car loads up and all the connectors are suspect, so I know that needs to be replaced.
The other issue is a fuel leak- I thought it was a seal or injector, so I replaced all the seals and 4 new injectors. Now when I start the car, no leaks, then after a minute running, it starts leaking just below the injector. I can't see where from but it's a decent leak. Just cyl 2 and not always does it leak. I removed, reseated the injector and it was fine for another minute, then leaked again. Could it be a bad pressure regulator? What am I missing?
