How test/inspect 2.0L DJet throttle body before swapping it in? |
Tdskip |
Mar 16 2022, 07:05 PM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Hi - the '75 DJet car has a stumble that happens at a couple points in the rev range and at certain RPMs when the throttle is held constant. It rarely happens when the throttle is being exercised up/down the RPM range (like accelerating through turns etc).
I'm thinking worn throttle body "fingers" or the trace pad they travel against (yeah, wrong terms I know) but I believe this could also (maybe) be a sticky advance weight in the distributor. Any why to test the spare throttle body so I don't swap out the wrong thing? OR Should I just pull and open the plastic cover on the one I have to see what is up? Doesn't look that hard to remove it. What say you gentlemen, and please do liberally apply terminology dope slaps. Thanks! |
Lo-Fi Version | Time is now: 24th May 2024 - 06:19 PM |
