WTB: brake calipers 3” fronts, e-brake capable rears |
grantjd |
Mar 21 2022, 09:37 AM
Newbie Group: Members Posts: 9 Joined: 29-January 09 From: CO Member No.: 9,997 Region Association: Rocky Mountains |
Looking for my brake caliper setup.
Fronts- 3” strut spacing for vented rotors. Looking for M calipers/ Alfa Brembos/ etc. seeing whats out there, may be prudent to just go with the Brembos straight from PMB. 48mm piston. Rears- looking for e-brake function. 914/6 rears of whatever type, or M’s with the 911 ebrake setup/ 308 calipers, etc. Must be 38mm piston. Again, might be prudent to go with the /6 calipers straight away, but seeing whats out there. Looking to retain stock regulator setup and bias. Running a 19mm m/c |
914Sixer |
Mar 21 2022, 11:04 AM
Put a WTB over on the Pelican 911 Classified for calipers. Doubt PMB has any Brembos in stock. New ATE front calipers can be had for about $350 each. Dansk reproductions are $250. Shop around.
eric9144 |
Mar 21 2022, 11:25 AM
Advanced Member Group: Members Posts: 2,734 Joined: 30-March 11 From: San Diego, CA Member No.: 12,876 Region Association: Southern California |
Keeping 4 lug or going to 5?
If you're keeping it 4 bolt, I have a collection of unicorn parts but have to get pictures. |
jcd914 |
Mar 21 2022, 09:39 PM
I have a pair of used aluminum Alfa Brembo calipers, I paid too much for a few years ago.
Condition is unknown, I've done nothing with them since I got them. Jim |
brant |
Mar 22 2022, 09:29 AM
Grant,
nice to see a colorado member! are you using different struts (911) or special hubs for the vented set up? brant |
brant |
duplicate post
grantjd |
Mar 22 2022, 09:07 PM
Using a 3" 911 front end, vented
d914 |
Mar 26 2022, 02:07 PM
[quote name='grantjd' post='2989766' date='Mar 21 2022, 11:37 AM']
Looking for my brake caliper setup. Fronts- 3” strut spacing for vented rotors. Looking for M calipers/ Alfa Brembos/ etc. seeing whats out there, may be prudent to just go with the Brembos straight from PMB. 48mm piston. Rears- looking for e-brake function. 914/6 rears of whatever type, or M’s with the 911 ebrake setup/ 308 calipers, etc. Must be 38mm piston. Again, might be prudent to go with the /6 calipers straight away, but seeing whats out there. Looking to retain stock regulator setup and bias. Running a 19mm m/c Never mind didn’t see vented. G |
eric9144 |
Mar 28 2022, 01:36 PM
@grantjd keeping 4 lug or going 5? If you're not, then ignore this because part of this offer is the club hubs.
I ask because I sold my 4 cyl car after acquiring 4 bolt "unicorn" set up---I am about to list this FS but haven't just yet, I'm *not* breaking up the kit yet either. 2 Sets of "Club Hubs" w rotors-these are for 4 bolt wheels-vented disk hats for stock spindles Brembo alloy front calipers for vented disks a la PMB, pads etc loaded out 9146 GT rear calipers for vented disks a la PMB, pads etc. loaded out Rear disks In this use case the rear disks need to be redrilled for the 4x130 bolt pattern and will allow the use of 'stock' wheels, which was what I was going for, for the sleeper look. Not all parts are pictured $3500 Firm |
Mar 28 2022, 01:44 PM
@grantjd keeping 4 lug or going 5? If you're not, then ignore this because part of this offer is the club hubs. I ask because I sold my 4 cyl car after acquiring 4 bolt "unicorn" set up---I am about to list this FS but haven't just yet, I'm *not* breaking up the kit yet either. 2 Sets of "Club Hubs" w rotors-these are for 4 bolt wheels-vented disk hats for stock spindles Brembo alloy front calipers for vented disks a la PMB, pads etc loaded out 9146 GT rear calipers for vented disks a la PMB, pads etc. loaded out Rear disks In this use case the rear disks need to be redrilled for the 4x130 bolt pattern and will allow the use of 'stock' wheels, which was what I was going for, for the sleeper look. Not all parts are pictured $3500 Firm Cool setup. I like the stealth tech. |
dug |
Mar 30 2022, 11:16 AM
Member Group: Members Posts: 182 Joined: 26-December 06 From: Santa Cruz, CA Member No.: 7,382 Region Association: Northern California |
M calipers on pelican
http://forums.pelicanparts.com/porsche-911...-3-spacing.html |
Lo-Fi Version | Time is now: 15th May 2024 - 01:05 PM |
