Options for Countersunk-Head Screw, Part Number: 999.148.005.0E |
Tdskip |
Mar 30 2022, 07:25 PM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
These are the ones that secure the metal trim on the windshield pillars and rear of the cabin that in turn hold the seals in place;
Countersunk-Head Screw, 911 (66-67) Part Number: 999.148.005.0E are $10.09 each. Yeah, not feeling that. Anything that makes these 5x15 Countersunk Screw so special I can't try to find something similar from McMaster Carr? The front trim piece for reference is #27 here. Anyone been there and substituted that? Thanks! |
bkrantz |
Mar 30 2022, 09:07 PM
914 Guru Group: Members Posts: 7,766 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
I think I got those from Belmetric, in stainless.
Mikey914 |
Mar 31 2022, 05:21 AM
The rubber man Group: Members Posts: 12,669 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Those screws are not countersunk. You could use countersunk, but may actually make it harder to find.
aharder |
Mar 31 2022, 05:37 AM
Advanced Member Group: Members Posts: 4,391 Joined: 6-September 11 From: Dallas Texas Member No.: 13,524 Region Association: Southwest Region |
I think I got those from Belmetric, in stainless. (IMG:style_emoticons/default/agree.gif) I also got mine from Belmetric |
Tdskip |
Mar 31 2022, 06:40 AM
bdstone914 |
Mar 31 2022, 08:54 AM
Thanks gentlemen, appreciate the info. Are they actually sheet metal screws, with a pointed tip? Or like this @tdskip That is not the correct style or size screw. I will check the correct size and i probably have new ones on hand. It is an oval head screw. |
Tdskip |
Mar 31 2022, 09:02 AM
Thanks Bruce!
bdstone914 |
Mar 31 2022, 09:38 AM
Thanks gentlemen, appreciate the info. Are they actually sheet metal screws, with a pointed tip? Or like this @tdskip That is not the correct style or size screw. I will check the correct size and i probably have new ones on hand. It is an oval head screw. The correct screw is a 2.9 x 10 oval head self tapping screw. I removed one to confirm. PET shows a 13mm lenght but they ofter superceed hardware part numbers to more common parts that will also work. I have them. You need 18 to install all four trim pieces. The original screw is on the dime. Attached thumbnail(s) |
mmichalik |
Mar 31 2022, 09:48 AM
MikeM Group: Members Posts: 697 Joined: 27-January 16 From: Valley Center, CA Member No.: 19,600 Region Association: Southern California |
I think I got those from Belmetric, in stainless. (IMG:style_emoticons/default/agree.gif) I've purchased a lot of screws in many different sizes from there. I used all black oxide on the car as well. |
Tdskip |
Mar 31 2022, 10:23 AM
bdstone914 |
Mar 31 2022, 10:30 AM
Chris914n6 |
Mar 31 2022, 12:12 PM
Jackstands are my life. Group: Members Posts: 3,320 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
1- you can get them from amazon/ebay easy.
2- the 4.2 cross references to a #6 iirc, so the 2.9 might be a #4 or something super common. |
Lo-Fi Version | Time is now: 17th May 2024 - 06:09 PM |
