Fikse fitment |
Fikse fitment |
mb911 |
Apr 3 2022, 06:16 AM
914 Guru Group: Members Posts: 6,851 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I really want to buy a set for my car as maybe every other summer thing. I like the look. Would these fit my GT bodied car? I think they would but wanted to confirm.
https://forums.pelicanparts.com/porsche-911...sc-carrera.html |
Luke M |
Apr 3 2022, 06:58 AM
Senior Member Group: Members Posts: 1,372 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
I really want to buy a set for my car as maybe every other summer thing. I like the look. Would these fit my GT bodied car? I think they would but wanted to confirm. https://forums.pelicanparts.com/porsche-911...sc-carrera.html Ben, Check the back spacing of the wheels. I bought a set and had them restored locally. When I tested fitted them to my brothers GT style 914 the rears where super tight on the outer edge of the fender lip. The fronts where ok just rear issue. My set is 7.5x17 & 9x17. |
mb911 |
Apr 3 2022, 07:23 AM
I really want to buy a set for my car as maybe every other summer thing. I like the look. Would these fit my GT bodied car? I think they would but wanted to confirm. https://forums.pelicanparts.com/porsche-911...sc-carrera.html Ben, Check the back spacing of the wheels. I bought a set and had them restored locally. When I tested fitted them to my brothers GT style 914 the rears where super tight on the outer edge of the fender lip. The fronts where ok just rear issue. My set is 7.5x17 & 9x17. Luke, Did you buy new or used? I was just wondering if you were able to spec them out? |
carr914 |
Apr 3 2022, 08:27 AM
Racer from Birth Group: Members Posts: 118,670 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
sixnotfour |
Apr 3 2022, 04:06 PM
914 Wizard Group: Members Posts: 10,432 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Good news is you can add spacing for the look you want..
Luke M |
Apr 3 2022, 06:00 PM
I really want to buy a set for my car as maybe every other summer thing. I like the look. Would these fit my GT bodied car? I think they would but wanted to confirm. https://forums.pelicanparts.com/porsche-911...sc-carrera.html Ben, Check the back spacing of the wheels. I bought a set and had them restored locally. When I tested fitted them to my brothers GT style 914 the rears where super tight on the outer edge of the fender lip. The fronts where ok just rear issue. My set is 7.5x17 & 9x17. Luke, Did you buy new or used? I was just wondering if you were able to spec them out? Ben, I got the set used over on Pelican. The wheels came off a 86 911 Carrera and was told fit under the stock fenders. The fronts seam to clear without any tires on the wheels. I'm pretty sure the rears will not fit once the tires are mounted. I'll post a few pics on Monday. |
mb911 |
Apr 3 2022, 06:23 PM
I really want to buy a set for my car as maybe every other summer thing. I like the look. Would these fit my GT bodied car? I think they would but wanted to confirm. https://forums.pelicanparts.com/porsche-911...sc-carrera.html Ben, Check the back spacing of the wheels. I bought a set and had them restored locally. When I tested fitted them to my brothers GT style 914 the rears where super tight on the outer edge of the fender lip. The fronts where ok just rear issue. My set is 7.5x17 & 9x17. Luke, Did you buy new or used? I was just wondering if you were able to spec them out? Ben, I got the set used over on Pelican. The wheels came off a 86 911 Carrera and was told fit under the stock fenders. The fronts seam to clear without any tires on the wheels. I'm pretty sure the rears will not fit once the tires are mounted. I'll post a few pics on Monday. Ok |
Steve |
Apr 3 2022, 06:32 PM
914 Guru Group: Members Posts: 5,587 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
8x17 5-130mm (19mm) $700.00 Each 225x45x17
9x17 5-130mm (6mm) $725.00 Each 245x40x17 These are my Fikse FM10 and how much I paid for them new many years ago. |
BIGKAT_83 |
Apr 3 2022, 07:00 PM
Senior Member Group: Members Posts: 1,798 Joined: 25-January 03 From: Way down south Bogart,GA Member No.: 194 Region Association: South East States |
Same size as Steves wheels and fit fine with 255/40/17 on the rear and 235/45 on the front. The prices Steve posted have increased almost to double.
Apr 3 2022, 07:58 PM
sixnotfour |
Apr 3 2022, 08:16 PM
fuchs offset chart works no matter the dia.. The 15inch x9 offset not so much,, the 16 offset x 9 pretty much all GT flairs..
Steve |
Apr 4 2022, 08:48 AM
Same size as Steves wheels and fit fine with 255/40/17 on the rear and 235/45 on the front. The prices Steve posted have increased almost to double. I was also running your size tires, but when I switched from race tires to Michelin pilot sport tires, the curb rib on the tires were rubbing on the fender, so I downsized a bit. |
Luke M |
Apr 4 2022, 02:20 PM
I really want to buy a set for my car as maybe every other summer thing. I like the look. Would these fit my GT bodied car? I think they would but wanted to confirm. https://forums.pelicanparts.com/porsche-911...sc-carrera.html Ben, Check the back spacing of the wheels. I bought a set and had them restored locally. When I tested fitted them to my brothers GT style 914 the rears where super tight on the outer edge of the fender lip. The fronts where ok just rear issue. My set is 7.5x17 & 9x17. Luke, Did you buy new or used? I was just wondering if you were able to spec them out? Ben, I got the set used over on Pelican. The wheels came off a 86 911 Carrera and was told fit under the stock fenders. The fronts seam to clear without any tires on the wheels. I'm pretty sure the rears will not fit once the tires are mounted. I'll post a few pics on Monday. Ok Ben, Posted pics of the wheels. As you can see these are a tight fit. Other set is factory Fuchs 9x16 with 245-50-16 tires. Just as a comparison. The fuchs fit but tight also. I would need to roll the fender lip for a little extra room. The alignment has yet to be set as well so the fitment may change. Attached image(s) |
mb911 |
Apr 5 2022, 08:22 AM
Wow close. OK good to know.. these are on my short list.
Lo-Fi Version | Time is now: 17th May 2024 - 11:12 PM |
