Lug studs for minilite rims, Looking for a source to obtain lug studs |
g911 |
Apr 7 2022, 11:59 AM
Member Group: Members Posts: 222 Joined: 13-January 06 From: Not Tellin' Member No.: 5,413 Region Association: None |
I am trying to find some lug studs for a set of minilite rims. The hole through the rim is just under 16 mm. My guess is ~15.5 +/-0.2mm. The rim is close to 25 mm thick. Thread end would be 14 mm 1.5. I was thinking of a thread in stud to use regular lug nuts but the shank part that would fit into the rim would require enlarging the hole in the rim. Any help or sources would be appreciated.
Apr 7 2022, 12:31 PM
I have a set. Just have to find them. Give me a day or two and check in with a pm. Thanks mark
Van B |
Apr 7 2022, 01:24 PM
Senior Member Group: Members Posts: 1,586 Joined: 20-October 21 From: Maryland Member No.: 26,011 Region Association: None |
can I ask why you want studs instead of those bolts?
g911 |
Apr 7 2022, 02:10 PM
I want the bolts. I was exploring all options. I tried contacting Minilite America, but have not been successful in getting a response.
jrmdir |
Apr 7 2022, 02:41 PM
Member Group: Members Posts: 224 Joined: 13-May 21 From: Central Ohio Member No.: 25,544 Region Association: Upper MidWest |
I did a search and ran across this place. No mention of Porsche but they should know Minilites pretty well. Could be an info resource?
http://www.speedshack.co.uk/Wheelnuts.htm EDIT: Actually they do mention Porsche at the bottom. WHEELNUTS, WHEEL NUTS, WHEELBOLTS, LONGER WHEELSTUDS, LOCKNUTS / LOCKBOLTS AND WHEELSPACERS SUPPLIED FOR : ALFA ROMEO / AUDI / BMW / CATERHAM / CHEVROLET - GM / CHRYSLER / CITROEN / MOST TYPES OF CLASSIC CARS / DAEWOO / DAIHATSU / DODGE / DUTTON / FIAT / FORD / HOLDEN / HYUNDAI / ISUZU / JAGUAR / KIA / LADA / LANCIA / LAND ROVER / LEXUS / LOCOST / LOTUS / MAZDA / MERCEDES / MG / MITSUBISHI / MORGAN / NISSAN / OPEL / PEUGEOT / PORSCHE / PROTON / RENAULT / ROVER / RANGE ROVER / SAAB / SEAT / SKODA / SUBARU / SUZUKI / TOYOTA / TVR / VAUXHALL / VOLKSWAGEN VW BEETLE TRANSPORTER BUS T2 T2.5 T3 T4 T5/ VOLVO |
sixnotfour |
Apr 8 2022, 03:26 PM
914 Wizard Group: Members Posts: 10,432 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
new minis use different lug nut config..
71six |
Apr 10 2022, 01:43 PM
Member Group: Members Posts: 135 Joined: 4-July 03 From: Fitzwilliam,NH Member No.: 884 |
I am trying to find some lug studs for a set of minilite rims. The hole through the rim is just under 16 mm. My guess is ~15.5 +/-0.2mm. The rim is close to 25 mm thick. Thread end would be 14 mm 1.5. I was thinking of a thread in stud to use regular lug nuts but the shank part that would fit into the rim would require enlarging the hole in the rim. Any help or sources would be appreciated. Hi, If you still need the Minilite wheel studs I have 15 which were purchased from Brad Mayeur in March 2020. I went a different route and installed threaded wheel studs with shank type wheel bolts. |
g911 |
Apr 11 2022, 11:20 AM
I have pm’d mepstein, 71six and sent an email to speedshack, thanks jrmdir. I will update status. Thanks for continued help and leads.
Apr 11 2022, 12:06 PM
71six |
Apr 11 2022, 04:35 PM
Hi Gary,
I sent you a PM concerning the wheel studs. Mark |
71six |
Apr 11 2022, 04:40 PM
71six |
Apr 11 2022, 06:19 PM
g911 |
Apr 11 2022, 07:50 PM
Yes that is what I am looking for. I will PM.
Lo-Fi Version | Time is now: 17th May 2024 - 07:04 PM |
