WTB Fuel Tank |
WTB Fuel Tank |
Mowog4 |
Apr 10 2022, 05:28 PM
Member Group: Members Posts: 290 Joined: 2-November 15 From: Mesa AZ Member No.: 19,325 Region Association: None |
I am looking for a fuel tank, preferably in the Phoenix area. Any help is appreciated.
Ed |
Steve |
Apr 10 2022, 06:36 PM
914 Guru Group: Members Posts: 5,587 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Why buy a 50 year old rusted used one, when you can buy a new one.
https://www.pelicanparts.com/More_Info/9142...pAaAjghEALw_wcB Shop around I have seen them cheaper. |
Mowog4 |
Apr 10 2022, 07:49 PM
Why buy a 50 year old rusted used one, when you can buy a new one. https://www.pelicanparts.com/More_Info/9142...pAaAjghEALw_wcB Shop around I have seen them cheaper. Didn’t realize they were available. Thanks, I’ll order one |
brant |
Apr 11 2022, 06:30 AM
914 Wizard Group: Members Posts: 11,624 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I have a clean one in Colorado for sale
Complete with a fuel sender and the connector pipes I can find pictures if you want |
914Sixer |
Apr 11 2022, 08:57 AM
$229 at PartsGeek.
mgphoto |
Apr 11 2022, 09:09 AM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Specify early or late, early has a bracket for the charcoal canister, late does not, you don’t want to weld a bracket on a gas tank.
Robarabian |
Apr 11 2022, 09:22 AM
914 A Roo Group: Members Posts: 592 Joined: 11-February 19 From: Simi Valley, Kalifornia Member No.: 22,865 Region Association: Southern California |
I am looking for a fuel tank, preferably in the Phoenix area. Any help is appreciated. Ed @mm1 you want to chine in here on your research? |
MM1 |
Apr 11 2022, 01:26 PM
914 obsession continues Group: Members Posts: 608 Joined: 9-May 18 From: Thousand Oaks, CA Member No.: 22,105 Region Association: Southern California |
Just bought a new Dansk tank (up to 1973).
As stated above, if you plan on installing the expansion tank and charcoal canister, you need to know whether you need an early or late tank. AutoAtlanta has the correct pictures on their website which show the different bracketry for early and late tanks. Dansk's first 914 fuel tank reproductions do not have the correct bracketry for either generation (Partsgeek's photos showed the "generic" tank when I checked a few weeks ago). Thankfully, Dr. Hussey told me he sent them proper examples and new production has been corrected. If you don't care about the brackets the Partsgeek is the cheapest . . .however . . . Two of the suppliers (Partsgeek being one - I won't mention the other) weren't even aware of the facts above. Partsgeek couldn't check their stock, and the other supplier (NOT Pelican) did check for me and found that they had one of the "generic" tanks. I ultimately purchased from AA - the first (correct) tank arrived damaged from Empi (the SoCal dropshipper for Dansk tanks), but the second was fine. With the oversized shipping clause at AA, I did not know the total charge (tank+tax+shipping) until approximately a week after the purchase. Dr. Hussey and his staff were very helpful with my first large purchase from them (I ordered more than the tank). Thank you to AutoAtlanta (and Empi)! Pelican's price (around $300) included shipping (I believe) and may have ultimately been approximately $15 cheaper than AA . . .but I didn't check (read "grill") with them in order to definitively determine whether their tanks had the proper brackets (the box would have to be opened prior to shipping). |
MM1 |
Apr 11 2022, 01:37 PM
Pelican's tank pictures do not appear to show the correct brackets.
Due diligence required here. If I had another 4 hours+ to blow on this (about what I have into it jumping in cold), I'd help you out. You should be able to shave 3 hours off that with the points mentioned above - good luck! You can have my old rusty one for free - but I guess you already have a few of those - lol |
jims914 |
Apr 11 2022, 03:27 PM
Member Group: Members Posts: 125 Joined: 11-March 11 From: Tempe,AZ Member No.: 12,816 Region Association: Southwest Region |
Pelican's tank picture do not appear to show the correct brackets. Due diligence required here. If I had another 4 hours+ to blow on this (about what I have into it jumping in cold), I'd help you out. You should be able to shave 3 hours off that with the points mentioned above - good luck! You can have my old rusty one for free - but I guess you already have a few of those - lol I have a nice late clean one in Tempe, AZ $125.00 |
Mowog4 |
Apr 19 2022, 09:30 AM
I ordered the late model tank from AA, expect it this week. Thanks for the help.
BillJ |
Apr 19 2022, 09:47 AM
Senior Member Group: Members Posts: 1,098 Joined: 4-March 13 From: charlotte, NC Member No.: 15,610 Region Association: None |
Also be aware that, unless it has been corrected, the rib that runs on the top is a little too tall for the plastic tank strap guide and will crack it when you tighten the strap. You can either cut a small channel in the guide or grind some material off the rib. I have a thread here on my install.
MM1 |
Apr 19 2022, 11:25 AM
Lo-Fi Version | Time is now: 18th May 2024 - 05:37 AM |
