Fuel pump relocation, Finally to the front |
nditiz1 |
Apr 12 2022, 11:59 PM
Senior Member Group: Members Posts: 1,188 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
So I'm finally going to put my pump up front. This is the CB Performance rotary 3193 (thanks Glen).
I know some of you can remember my car briefly having a 2.7 EFI with ITB's, but I'm in the middle of a trade right now - 2.7 shipped out and I will be getting a 2.4 with dual Zeniths. While the power is down and not as cool as the EFI ITB, it will be much easier to tune as well as drop in and go. The 2.7 had a major oil leak with one of the through bolts it appeared. Oh and no need for a front Oil cooler (I think). But I digress, this should be pretty simple. Go through the filter on the right, to the pump, and then to another filter (not pictured), then to the main line. I am thinking about getting a cap for the return line. I never really like clamping onto a bolt. I guess I could... Lastly I will be installing a relay. Need to pull power from somewhere. Clay had mentioned to use fuse #8 to send the signal to the relay. What are others using for the constant power? That condensor/box is definitely coming out and into the trash (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-18763-1649829549.1.jpg) |
Cairo94507 |
Apr 13 2022, 09:49 AM
Michael Group: Members Posts: 9,759 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Good modification and needed in our cars. (IMG:style_emoticons/default/beerchug.gif)
Van B |
Apr 13 2022, 10:00 AM
Senior Member Group: Members Posts: 1,586 Joined: 20-October 21 From: Maryland Member No.: 26,011 Region Association: None |
I recently discovered my relocated FP was tapped into the coil wire on the relay board, no bueno. I was able to tap into the original fuel pump wires under the car that had been snipped and tucked up into the hell hole and ran 14 AWG wires through the tunnel to the front.
Lo-Fi Version | Time is now: 17th May 2024 - 08:45 PM |
