FAT Upright Fan Shroud question |
Charles Freeborn |
Apr 15 2022, 10:19 AM
Member Group: Members Posts: 249 Joined: 21-May 14 From: United States Member No.: 17,377 Region Association: Pacific Northwest |
The engine that came with my new track 914 also came with the 911 fan conversion from FAT. I haven't gotten a very good answer from Fat on what other tins I should install with it. Obviously upper and side tins are replaced, but how about the lowers? Any other sheetmetal or deflectors that are part of the system? It was all apart when I got it, and so far I've found (or not found) some other missing bits as it wasn't disassembled or cataloged upon disassembly very well.
Thx. |
infraredcalvin |
Apr 15 2022, 09:41 PM
Distracted Member Group: Members Posts: 1,517 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California |
Not that mine is right, I did blow it up after all, but mine only had the lower tin, under the cylinders installed, no other tin.
Charles Freeborn |
Apr 16 2022, 04:36 PM
Not that mine is right, I did blow it up after all, but mine only had the lower tin, under the cylinders installed, no other tin. Many thanks. This appears to have been the case on mine. One lower tin in evidence, the other missing so I assume lost in the teardown at some point. The remaining one has some additional vent holes in it which I'll ponder when I get to reassembly. |
Lo-Fi Version | Time is now: 18th May 2024 - 06:44 AM |
