Blaupunkt face plate mounting |
Cal |
Apr 17 2022, 06:39 AM
Senior Member Group: Members Posts: 615 Joined: 19-November 14 From: Philadelphia Member No.: 18,138 Region Association: North East States |
Dumb question about mounting the vinyl covered face plate for my Blaupunkt. Is the face plate only held into place with double face tape or with additional mounting nuts to the radio shafts? I have all the miscellaneous parts / pieces, as in the photo below, the problem is that there doesn’t appear to be enough exposed threads on the radio shafts when the radio is mounted to install additional mounting nuts if they’re needed. The only thing holding the face plate in-place would be the double face tape and the radio knobs....is that correct.
Attached thumbnail(s) |
914Sixer |
Apr 17 2022, 07:44 AM
Brackets on the right support and hold shafts. Two rear C brackets support the rear, So, the face plate is just for cover. There was another version of face plate with small holes. I like the small hole best but you are good to go.
Really rare installation kit. |
jdamiano |
Apr 17 2022, 08:04 AM
Member Group: Members Posts: 335 Joined: 18-March 18 From: Jacksonville Member No.: 21,981 Region Association: South East States |
I just pieced together all those same parts to install my radio. You should be good to go. The plate doesn’t need any tape. It is held in place by the radio.
rgalla9146 |
Apr 17 2022, 07:11 PM
Advanced Member Group: Members Posts: 4,554 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
The double face foam tape positions the panel accurately......square to the heat/vent
control panel and level with its surface. |
DC_neun_vierzehn |
Apr 17 2022, 09:12 PM
Member Group: Members Posts: 378 Joined: 16-November 20 From: Delaware Shore Member No.: 24,893 Region Association: MidAtlantic Region |
Lo-Fi Version | Time is now: 17th May 2024 - 06:48 PM |
