Beware replacement 1.7 injector and hoses supplied with them, Cracking after installing a few weeks ago |
jhynesrockmtn |
Apr 29 2022, 03:13 PM
Member Group: Members Posts: 418 Joined: 13-June 16 From: spokane wa Member No.: 20,100 Region Association: Pacific Northwest |
I bought the common replacement 1.7 liter fuel injectors from rock auto about a month ago. They are installed on an engine that was removed for some out of the car maintenance. I only put them on there a few weeks ago. They are already splitting at the bend. I guess I'm gonna be cutting them off and reinstalling the pre bent hoses that I had bought new a year ago.
mgphoto |
Apr 29 2022, 05:02 PM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
I bought the common replacement 1.7 liter fuel injectors from rock auto about a month ago. They are installed on an engine that was removed for some out of the car maintenance. I only put them on there a few weeks ago. They are already splitting at the bend. I guess I'm gonna be cutting them off and reinstalling the pre bent hoses that I had bought new a year ago. I found the same issue, cheap hoses, with the 2.0L version, I was installing them on the fuel rail and I bent the hose to better conform to the space and the bronze ring deformed. I didn’t need to cut them off, just some hard tugging they came apart, I also used the bent hoses I already had. FYI the 2.0L injector version works very well. |
jhynesrockmtn |
Apr 30 2022, 03:14 PM
I bought the common replacement 1.7 liter fuel injectors from rock auto about a month ago. They are installed on an engine that was removed for some out of the car maintenance. I only put them on there a few weeks ago. They are already splitting at the bend. I guess I'm gonna be cutting them off and reinstalling the pre bent hoses that I had bought new a year ago. I found the same issue, cheap hoses, with the 2.0L version, I was installing them on the fuel rail and I bent the hose to better conform to the space and the bronze ring deformed. I didn’t need to cut them off, just some hard tugging they came apart, I also used the bent hoses I already had. FYI the 2.0L injector version works very well. Just finished this. I used a small dremel cutoff wheel to cut the brass slightly and they pulled right off. |
Lo-Fi Version | Time is now: 18th May 2024 - 08:34 AM |
