motorvated |
Member ![]() ![]() Group: Members Posts: 282 Joined: 13-February 13 From: Colorado Member No.: 15,519 Region Association: Rocky Mountains ![]() |
A friend just gave me an old but unused Norris Camshaft No. 366-13 and I can't seem to find any information about it. There is a tag on it that is hard to read but might state:
0.490" lift 0.008" valve lash 10 54 deg BTC EC 80 BBC 1C 74 deg ABC EC 48 ATC I was told that it is a pretty radical race cam that is not suitable for a street car. Not a problem for me as I am planning to do a performance race build on my 2.0 liter Type IV at the end of this race season. Anyone know anything about this cam and/or have any experience with it or something with similar specifications. Thanks, Mike S. |
Charles Freeborn |
Member ![]() ![]() Group: Members Posts: 282 Joined: 21-May 14 From: United States Member No.: 17,377 Region Association: Pacific Northwest ![]() |
Webcam publishes all their specs.
Start with an 86b and go from there. A friend just gave me an old but unused Norris Camshaft No. 366-13 and I can't seem to find any information about it. There is a tag on it that is hard to read but might state: 0.490" lift 0.008" valve lash 10 54 deg BTC EC 80 BBC 1C 74 deg ABC EC 48 ATC I was told that it is a pretty radical race cam that is not suitable for a street car. Not a problem for me as I am planning to do a performance race build on my 2.0 liter Type IV at the end of this race season. Anyone know anything about this cam and/or have any experience with it or something with similar specifications. Thanks, Mike S. |
stownsen914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 947 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None ![]() |
I’ve heard of Norris, they may have done Porsche 355 grinds as well. Out of curiosity I googled but could only turn up VW type 1 grinds.
Brett W |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,859 Joined: 17-September 03 From: huntsville, al Member No.: 1,169 Region Association: None ![]() ![]() |
A friend just gave me an old but unused Norris Camshaft No. 366-13 and I can't seem to find any information about it. There is a tag on it that is hard to read but might state: 0.490" lift 0.008" valve lash 10 54 deg BTC EC 80 BBC 1C 74 deg ABC EC 48 ATC I was told that it is a pretty radical race cam that is not suitable for a street car. Not a problem for me as I am planning to do a performance race build on my 2.0 liter Type IV at the end of this race season. Anyone know anything about this cam and/or have any experience with it or something with similar specifications. Thanks, Mike S. Some fiddling with a caluculator suggests that is a pretty rowdy camshaft. Intake Duration is 308.00 degrees. Exhaust Duration is 316.00 degrees. Installed Intake Centerline is 100.00 degrees ATDC. Installed Exhaust Centerline is 110.00 degrees BTDC. LSA is 105.0 degrees Overlap is 102.00 degrees. That will require a lot of compression and will require RPM to make power. Nothing wrong with that as long as you are building race engine. |
motorvated |
A friend just gave me an old but unused Norris Camshaft No. 366-13 and I can't seem to find any information about it. There is a tag on it that is hard to read but might state: 0.490" lift 0.008" valve lash 10 54 deg BTC EC 80 BBC 1C 74 deg ABC EC 48 ATC I was told that it is a pretty radical race cam that is not suitable for a street car. Not a problem for me as I am planning to do a performance race build on my 2.0 liter Type IV at the end of this race season. Anyone know anything about this cam and/or have any experience with it or something with similar specifications. Thanks, Mike S. Some fiddling with a caluculator suggests that is a pretty rowdy camshaft. Intake Duration is 308.00 degrees. Exhaust Duration is 316.00 degrees. Installed Intake Centerline is 100.00 degrees ATDC. Installed Exhaust Centerline is 110.00 degrees BTDC. LSA is 105.0 degrees Overlap is 102.00 degrees. That will require a lot of compression and will require RPM to make power. Nothing wrong with that as long as you are building race engine. So what is "a lot of compression", over 8.5? And if "installed intake centerline" is 100 degrees ATDC, specifically how do I internally time this camshaft using a degree wheel? And what kind/type of solid lifters will work with this cam? And thank you for your knowledgeable reply! And Yes it will go in a race motor, either a 2.0 liter or 1.8 of increased displacement. Must stay below 2.0 liter threshold to run Vintage. |
Brett W |
Compression above 10:1 would be preferable. Depending on piston design and race class limits, I would push as high as possible 13-14:1 would be nice. This engine will need race fuel.
Camshaft timing can be adjusted with offset Key ways, bushings in the bolt holes, etc. You will need an aftermarket timing set. Pauter Machine used to make a nice straight cut steel setup. I ran that on my street car when I was 25. HAHA. Its pretty loud. You will have to assemble and disassemble the motor several times to properly degree the camshaft. Its far from easy, like some other engines. I would build the biggest engine you can get away with. If 2.0 is the limit build it to 2056. As for lifters, Web made good lifters, but who knows now. Ceramics would be nice but are unobtanium right now. Talk to L&N engineering about what is working best for them and what they sell currently. |
Lo-Fi Version | Time is now: 13th May 2025 - 05:12 AM |
