Help needed on a part, Where does this rubber pad go? |
mxkinn01 |
May 4 2022, 01:57 PM
Member Group: Members Posts: 228 Joined: 18-June 17 From: Las Vegas, NV Member No.: 21,195 Region Association: Southwest Region |
Hello Everyone,
In the process of moving my fuel pump up front to the 75-76 style. Once the tank was out I found this (to the right of the blister panel and bracket) little rectangular rubber pad beneath it. Ill be damned if I can find where it goes. I would assume its bumper of some sorts down there. Please chime in if you know where it goes. Also, does anybody have an extra set of 75-76 fuel pump rubber mounts that goes between the blister cover and the bracket, Or the part number so I can get a set? |
mxkinn01 |
May 4 2022, 05:37 PM
OK Guys,
Pelican had the rubber bushings and a new fuel pump clamp, they are on order. Still need to know where the rectangular rubber pad goes???? Any help would be much appreciated. Thanks Mike |
jim_hoyland |
May 4 2022, 06:51 PM
Get that VIN ? Group: Members Posts: 9,301 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Between the pump and the bracket; it’s a damper…. (IMG:style_emoticons/default/smile.gif)
mxkinn01 |
May 4 2022, 07:39 PM
Hey Jim,
Thanks for the reply. But since mine is a 73 with the pump in rear I wouldn't think one of those would be underneath the tank. I will be cutting a hole where the blister panel will go to update to the 75-76 position and pump. I kinda thought it was some type of bumper for the tank in addition to the factory felt pads???? I'm stumped as to where it goes. I also found 5 omega air box clips (PITA to put back on) and that small rectangle rubber pad just hanging out under the tank down by the fuel lines. Obviously someone had been in there before. I'm counting on this fuel pump relocation to eliminate the vapor lock issues I have every summer. |
rgalla9146 |
May 5 2022, 06:47 AM
Advanced Member Group: Members Posts: 4,554 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Hey Jim, Thanks for the reply. But since mine is a 73 with the pump in rear I wouldn't think one of those would be underneath the tank. I will be cutting a hole where the blister panel will go to update to the 75-76 position and pump. I kinda thought it was some type of bumper for the tank in addition to the factory felt pads???? I'm stumped as to where it goes. I also found 5 omega air box clips (PITA to put back on) and that small rectangle rubber pad just hanging out under the tank down by the fuel lines. Obviously someone had been in there before. I'm counting on this fuel pump relocation to eliminate the vapor lock issues I have every summer. My first thought was between the pump and the bracket but as noted it would not be found in a '73 Wasn't there a rubber pad under the half-round bulge on the air box and the body ? ......glued to the body as an anti-squeek ? The air box clips can be opened with a circlip pliers and slid on from the side. |
mxkinn01 |
May 5 2022, 08:50 AM
Hey Jim, Thanks for the reply. But since mine is a 73 with the pump in rear I wouldn't think one of those would be underneath the tank. I will be cutting a hole where the blister panel will go to update to the 75-76 position and pump. I kinda thought it was some type of bumper for the tank in addition to the factory felt pads???? I'm stumped as to where it goes. I also found 5 omega air box clips (PITA to put back on) and that small rectangle rubber pad just hanging out under the tank down by the fuel lines. Obviously someone had been in there before. I'm counting on this fuel pump relocation to eliminate the vapor lock issues I have every summer. My first thought was between the pump and the bracket but as noted it would not be found in a '73 Wasn't there a rubber pad under the half-round bulge on the air box and the body ? ......glued to the body as an anti-squeek ? The air box clips can be opened with a circlip pliers and slid on from the side. Hmmm. Didn't think of that. If that's where it goes, I'll just put in my spare part stash and glue it in there if I ever have the air box out. As of now it works fine and no squeaks. |
Mikey914 |
May 5 2022, 01:59 PM
The rubber man Group: Members Posts: 12,669 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I thought the one under the air box was a piece of perlon. Let me know if I'm wrong on that. It's been awhile.
Mark |
Root_Werks |
May 5 2022, 02:41 PM
Village Idiot Group: Members Posts: 8,321 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Yup, mine doesn't have that little square pad and you can tell. |
rgalla9146 |
May 5 2022, 07:51 PM
Yes, it could have been perlon....not sure, but know I've seen something in that spot.
Mikey914 |
May 5 2022, 09:26 PM
Lo-Fi Version | Time is now: 18th May 2024 - 06:52 PM |
