Rev Limit Rotor failing:, What's the non-limit rotor part? |
Root_Werks |
May 5 2022, 11:10 AM
Village Idiot Group: Members Posts: 8,324 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
The mechanical rev-limiting rotor on my 914-6 2.7 is starting to fail. Not sure if sitting around for the 8 months did it in or just getting old?
For the stock 2.7 dist, I thought it was the Bosch 04033 non-limit rotor that could replace it? Can anyone help confirm that? I don't need a rev-limit rotor. https://www2.cip1.com/bos-04033/ Sort of thought the 04033 fit a ton of applications. |
914Sixer |
May 5 2022, 12:29 PM
914 Guru Group: Members Posts: 8,889 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Yes, should fit with no trouble. It is rare a rev limiter would fail. Just a weighted spring to short out a selected speed.
pbanders |
May 6 2022, 01:20 PM
Senior Member Group: Members Posts: 939 Joined: 11-June 03 From: Phoenix, AZ Member No.: 805 |
Yes, should fit with no trouble. It is rare a rev limiter would fail. Just a weighted spring to short out a selected speed. Agree. My suggestion is to use a cleaner like Deoxit to clean the limiter mechanism and contacts. My question to the OP is: how is it that you know it's failing? What's it doing? |
silverg |
May 6 2022, 01:41 PM
914s since March 1970 Group: Members Posts: 54 Joined: 7-June 06 From: Winchester, VA Member No.: 6,179 Region Association: MidAtlantic Region |
My experience - 914/6 race car first time on track with MSD/high output coil destroyed rev limit rotor. Had to grab a rotor from a VW to continue on.
Root_Werks |
May 6 2022, 02:08 PM
My experience - 914/6 race car first time on track with MSD/high output coil destroyed rev limit rotor. Had to grab a rotor from a VW to continue on. I believe that is what's happening to mine. Using the MSD coil and 6A series box. It's been over time, would "shut off" spark just over 6K and more recently keeps shutting things down at slightly lower RPM's. The rotor is of unknown age. Ordered up a couple of 04033's along with caps for both my Bug and 914-6. I like to have a stock. I don't have the 6AL, but this won't be a tracked car or driven abusively. Spirited yes, to limits, no. (IMG:style_emoticons/default/driving.gif) |
Lo-Fi Version | Time is now: 23rd May 2024 - 07:35 PM |
