3.2 with 914 transmission: sensor locations, Where do I cut the housing? |
Mitox |
May 18 2022, 07:22 PM
Member Group: Members Posts: 395 Joined: 26-October 15 From: SW Virginia Member No.: 19,302 Region Association: South East States |
I’ve disassembled my 914 trans, so I can clean and paint the case prior to a rebuild. It will be hooked up to a 3.2 retaining the fuel injection and Motronics. Before it is painted I’d like to cut the notches needed in the case for the Motronic sensors, but I don’t have a clue where to cut.
Can anyone point me in the right direction, or better yet, have measurements or a template for the cuts. Thanks for any help you may have |
mepstein |
May 18 2022, 08:07 PM
914-6 GT in waiting Group: Members Posts: 19,255 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
SirAndy |
May 18 2022, 08:28 PM
Resident German Group: Admin Posts: 41,623 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Not the best pictures but i don't remember this being especially difficult.
Test fit the trans, mark the sensor location, cut. (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:http://www.914world.com/bbs2/uploads/post-179-1181192469.jpg) (IMG:http://www.914world.com/bbs2/uploads/post-179-1185423324.jpg) (IMG:http://www.914world.com/bbs2/uploads/post-179-1181191642.jpg) |
Steve |
May 18 2022, 09:05 PM
914 Guru Group: Members Posts: 5,577 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
All I did was slide the 914 gear box onto the 3.2 motor as far as I could and then mark with a felt pen where the trans hit the two sensors and cut out a notch with a dremel tool.
mepstein |
May 18 2022, 09:56 PM
All I did was slide the 914 gear box onto the 3.2 motor as far as I could and then mark with a felt pen where the trans hit the two sensors and cut out a notch with a dremel tool. I remember this is what we did when we notched my trans. (IMG:style_emoticons/default/beerchug.gif) |
Mitox |
May 20 2022, 03:28 PM
Thanks for the direction everyone. I’ll mount the case to the engine next weekend; first
I’ll need to dig out the sensors and mount them. Hopefully they’re in one of the boxes I’ve not opened for a few years now. |
worn |
May 20 2022, 05:21 PM
can't remember Group: Members Posts: 3,150 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
Thanks for the direction everyone. I’ll mount the case to the engine next weekend; first I’ll need to dig out the sensors and mount them. Hopefully they’re in one of the boxes I’ve not opened for a few years now. It isn’t that hard. Angle grinder, sawzall, file. Your choice. I lined things up on the studs and semi-measured and eyeballed. Of course I didn’t want to look like an amateur, so I drew lines with a Sharpie. Fit just fine without letting too much of the elements in. Good luck with the search for your parts stashed away! |
Tdskip |
May 20 2022, 06:44 PM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Same here - passenger side near top.
Maltese Falcon |
May 20 2022, 07:37 PM
Advanced Member Group: Members Posts: 4,637 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
In the days of 3.2 Vanagon conversions, I used to send out a "Hard-Wire" template of the DME sensors cut out; this had a semi-circle bend to it which mates to the upper bell-housing bolt hole (locator). >>passenger side for the mid-engine (drivers side) for the Vanagon.
The opposite end of the Wire had the contour (DME sensor area) from a g50 or 915 gearbox, which just places down + sharpie the pattern. I just went to a friendly Independent Porsche shop and they let me make the pattern from a trans that was on a pallet. (IMG:style_emoticons/default/marty914.jpg) |
Mitox |
May 20 2022, 08:20 PM
In the days of 3.2 Vanagon conversions, I used to send out a "Hard-Wire" template of the DME sensors cut out; this had a semi-circle bend to it which mates to the upper bell-housing bolt hole (locator). >>passenger side for the mid-engine (drivers side) for the Vanagon. The opposite end of the Wire had the contour (DME sensor area) from a g50 or 915 gearbox, which just places down + sharpie the pattern. I just went to a friendly Independent Porsche shop and they let me make the pattern from a trans that was on a pallet. (IMG:style_emoticons/default/marty914.jpg) I like your wire template idea. Just wish there were a Porsche shop or two nearby; maybe one in Roanoke. Sometimes living in the mountains is inconvenient, but only sometimes. |
Lo-Fi Version | Time is now: 5th May 2024 - 06:28 PM |
